NETGEAR 8 x 100M/1G/2.5G/5G/10GBASE-T Port Card For M4300-96X
Quicklinx: DF3RWS00 Mfr#: APM408C-10000S
Hurry, only 1 left in stock!
£841.97 ex VAT
£1,010.36 inc VAT
Compatible with M4300-96X models (XSM4396K0, XSM4396K1). The NETGEAR M4300-96X is a 2RU modular switch that comes either empty or pre-populated with 48 SFP+ ports and supporting up to 96-port 10GBASE-T copper (RJ-45) with first 48 ports capable of PoE+, 96-port 10GBASE-X fiber (SFP+), 24-port 40GBASE-X fiber (QSFP+), or a combination. The M4300 family provides world-class services for server and storage interconnect, mid-enterprise edge and SMB core. SDVoE-Ready, M4300 switches streamline AV-over-IP deployments with Zero Touch multicast. Layer 3 feature set includes static, policy-based and dynamic routing as standard.
  • Versatile connectivity
    With an array of RJ-45 connectors, this NETGEAR APM408C expansion module offers versatile connectivity options, supporting 1/2.5/5/10 GBase-T interfaces. It's designed to meet the demands of diverse network environments, ensuring compatibility with various Ethernet standards.
  • High-speed data transfer
    Achieve up to 10 Gbps data transfer rates with the NETGEAR APM408C. This expansion module is engineered for high-performance networking, facilitating swift data link protocols including 10 Gigabit Ethernet, 2.5 Gigabit Ethernet, 5 Gigabit Ethernet, Fast Ethernet, and Gigabit Ethernet.
  • Seamless integration
    The plug-in module form factor of the NETGEAR APM408C ensures seamless integration into existing network setups. Its design promotes easy installation, making it a straightforward solution for expanding your network's capabilities.
NETGEAR APM408C - expansion module - 1/2.5/5/10GBase-T x 8
Expansion module
Plug-in module
Ports
370 g
Worldwide
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
Data Transfer Rate
10 Gbps
Expansion module
Plug-in module
Worldwide
Ports
Wired
Cabling Type
Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
10 Gbps
8 x 1/2.5/5/10GBase-T - RJ-45 - female
370 g
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Protocol: Fast Ethernet
Protocol: 10 Gigabit Ethernet
Protocol: 5 Gigabit Ethernet
Protocol: 2.5 Gigabit Ethernet
Form Factor: Plug-in module
Type: Expansion module
Brand: NETGEAR
Price Range Ex VAT: £750 - £1000
