Compatible with M4300-96X models (XSM4396K0, XSM4396K1). The NETGEAR M4300-96X is a 2RU modular switch that comes either empty or pre-populated with 48 SFP+ ports and supporting up to 96-port 10GBASE-T copper (RJ-45) with first 48 ports capable of PoE+, 96-port 10GBASE-X fiber (SFP+), 24-port 40GBASE-X fiber (QSFP+), or a combination. The M4300 family provides world-class services for server and storage interconnect, mid-enterprise edge and SMB core. SDVoE-Ready, M4300 switches streamline AV-over-IP deployments with Zero Touch multicast. Layer 3 feature set includes static, policy-based and dynamic routing as standard.
Versatile connectivity
The NETGEAR APM408P expansion module offers a wide range of connectivity options with its RJ-45 female connectors, supporting data link protocols from Fast Ethernet to 10 Gigabit Ethernet. This versatility ensures compatibility with various network speeds and types, making it an ideal choice for upgrading existing systems or deploying new ones. -
Enhanced power over Ethernet
Equipped with PoE+ capability, the APM408P allows for the delivery of power and data over a single cable to devices such as IP cameras, VoIP phones, and wireless access points. This feature simplifies installation and reduces cable clutter, making it perfect for businesses looking to expand their network infrastructure efficiently. -
High-speed performance
With a data transfer rate of up to 10 Gbps and support for multiple Ethernet standards, including 10GBase-T, the APM408P is designed to meet the demands of high-bandwidth applications. Whether it's for data centers, enterprise networks, or high-speed video streaming, this expansion module ensures reliable, high-speed connections.
 - NETGEAR APM408P - expansion module - 1/2.5/5/10GBase-T (PoE+) x 8
 - Expansion module
- Form Factor
 - Plug-in module
- Ports
 - 430 g
- Localisation
 - Worldwide
- Cabling Type
 - Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
- Data Link Protocol
 - 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
- Data Transfer Rate
 - 10 Gbps
 - IEEE 802.3af, IEEE 802.3at
 - Expansion module
- Form Factor
 - Plug-in module
- Localisation
 - Worldwide
- Ports
- Connectivity Technology
 - Wired
- Cabling Type
 - Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
 - 10 Gbps
 - PoE+
 - 8 x 1/2.5/5/10GBase-T (PoE+) - RJ-45 - female
 - 430 g
