NETGEAR 8-port Unmanaged Gigiabit Switch
Quicklinx: D5BXWS00 Mfr#: GS108PP-100EUS
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: [N/A]
Managed: No
POE: PoE+
£94.45 ex VAT
£113.34 inc VAT
The NETGEAR GS108PP is the industry’s first flexible PoE+ 8-Port Gigabit plug-and-play switch with 120W PoE budget. The Industry’s first flexible PoE+ integrated technology allows you to increase or decrease the PoE budget at any time to provide to your devices the power they need with interchangeable external power supply and an intuitive power selector. The flexible mounting options (rack-mount, wall-mount or desktop) and the compact and fanless design make the GS108PP an ideal option for any business or home.
  • Robust connectivity
    Equipped with 8 RJ-45 connectors supporting 1000Base-T for high-speed Gigabit Ethernet connections, the NETGEAR GS108PP ensures efficient networking and robust connectivity for all connected devices.
  • Enhanced power delivery
    Featuring Power over Ethernet Plus (PoE+) on all 8 ports with a generous 123 W PoE budget, this switch facilitates flexible installation of PoE devices such as IP cameras, VoIP phones, and wireless access points without the need for additional power supplies.
  • Optimized network performance
    With advanced features like 192KB packet buffer, Quality of Service (QoS), and support for jumbo frames up to 9 KB, the NETGEAR GS108PP is designed to optimize network performance, ensuring smooth data transmission and prioritization of bandwidth-intensive applications.
  • Durable and reliable
    The switch boasts an impressive MTBF (Mean Time Between Failures) of 2,752,476 hours, highlighting its reliability and durability in various operational environments, from desktop to rack-mount setups.
  • Energy-efficient operation
    Incorporating Energy Efficient Ethernet (IEEE 802.3az) and other energy-saving features, this switch reduces power consumption without sacrificing performance, making it an eco-friendly choice for your network infrastructure.
NETGEAR GS108PP - switch - 8 ports - rack-mountable
Switch - 8 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
123 W
Performance
Bandwidth: 16 Gbps
MAC Address Table Size
4K entries
Jumbo Frame Support
9KB
Flow control, full duplex capability, store and forward, WFQ, QoS, Energy Efficient Ethernet, 192KB packet buffer, CoS, DSCP support, EEE, WRR
IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
DC 54 V 2.4 A
23.6 cm x 10.2 cm x 2.7 cm
590 g
Europe
Switch - 8 ports
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
123 W
Performance
Bandwidth: 16 Gbps
4K entries
Jumbo Frame Support
9KB
Status Indicators
Power, PoE, link/activity/speed
8 x 1000Base-T RJ-45 PoE+ - 30 W
External power adapter
DC 54 V
Electric Current Required
2.4 A
128.6 Watt
Wall mounting kit
Rack Mounting Kit
Included
MTBF
2,752,476 hours
VCCI, BSMI, ICES-003, CB, FCC Part 15, EN 60950-1, LVD, KC, EAC, RCM
Europe
23.6 cm
10.2 cm
2.7 cm
590 g
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Ports: 8
Managed: No
POE: PoE+
Brand: NETGEAR
