NETGEAR 8-port POE+ Gigabit Unmanaged Switch
Quicklinx: DWF2WS00 Mfr#: GS108LP-100EUS
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: [N/A]
Managed: No
POE: PoE+
48 In Stock
£75.88 ex VAT
£91.05 inc VAT
The NETGEAR Gigabit Unmanaged Switch series helps businesses cost-effectively expand their network to Gigabit speeds and higher port counts. They are energy efficient, built to last, and rigorously tested to provide the reliability businesses need. 802.1p traffic prioritization and jumbo frame support allow for seamless integration with more sophisticated networks.
  • Instant connectivity with reliable performance
  • High quality components and energy efficiency
    NETGEAR switches are built with top quality components to assure a long life. They are built to last, and rigorously tested to provide the reliability businesses need. NETGEAR Unmanaged Switches also support the Energy Efficient Ethernet (IEEE 802.3az) standard, which reduces energy consumption when there is light traffic on an active port or when there is no link or no activity.
NETGEAR GS108LP - switch - 8 ports - rack-mountable
Switch - 8 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
60 W
Performance
Bandwidth: 16 Gbps
MAC Address Table Size
4K entries
Flow control, full duplex capability, store and forward, WFQ, QoS, Jumbo Frames support, fanless, Energy Efficient Ethernet, 192KB packet buffer, CoS, DSCP support, EEE, WRR
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
DC 54 V
23.6 cm x 10.2 cm x 2.7 cm
600 g
United Kingdom, Europe
Switch - 8 ports
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
60 W
Performance
Bandwidth: 16 Gbps
4K entries
Status Indicators
Power, PoE, link/activity/speed
8 x 1000Base-T RJ-45 PoE+
External power adapter
DC 54 V
67.5 Watt
Wall mounting kit
Rack Mounting Kit
Included
MTBF
2,752,476 hours
VCCI, BSMI, ICES-003, CB, FCC Part 15, EN 60950-1, LVD, KC, EAC, RCM
23.6 cm
10.2 cm
2.7 cm
600 g
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 8
Managed: No
POE: PoE+
Brand: NETGEAR
