Netgear's ProSAFE 8 port 10/100 Desktop Switch enables the instant connection of up to eight Ethernet devices at speeds up to 100 Mbps.
The compact size and durable metal case allow for easy placement anywhere. It is backed by a lifetime warranty.
- NETGEAR FS108v3 - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100
- Performance
- Bandwidth: 1.6 Gbps
- MAC Address Table Size
- 2K entries
- Flow control, auto-sensing per device, store and forward, 96KB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- 15.8 cm x 10.3 cm x 2.7 cm
- 390 g
- Localisation
- United Kingdom
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100
- Performance
- 2K entries
- Status Indicators
- Port status, power, link/activity
- 8 x 100Base-TX RJ-45
- Power Device
- External power adapter
- Voltage Required
- Included Accessories
- Wall mounting kit
- MTBF
- 4,200,000 hours
- C-Tick, cUL, EN 60950, UL 1950, FCC Part 15 Class B, IEC 950, EN 55022/CISPR 22 Class A, RU EAC
- Localisation
- United Kingdom
- 15.8 cm
- 10.3 cm
- 2.7 cm
- 390 g
- Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years , Technical support - lifetime
- 0 °C
- 40 °C
- 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
