Brand
NetGear 8 Port Fast Ethernet Switch
Quicklinx: B63CWS00 Mfr#: FS108-300UKS
Type: Fast Ethernet
Ports: 8
Data Transfer Rate: 100Mbps
Managed: No
POE: No
£23.87 ex VAT
£28.64 inc VAT
Netgear's ProSAFE 8 port 10/100 Desktop Switch enables the instant connection of up to eight Ethernet devices at speeds up to 100 Mbps.
The compact size and durable metal case allow for easy placement anywhere. It is backed by a lifetime warranty.
NETGEAR FS108v3 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Fast Ethernet
Ports
8 x 10/100
Performance
Bandwidth: 1.6 Gbps
MAC Address Table Size
2K entries
Flow control, auto-sensing per device, store and forward, 96KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
15.8 cm x 10.3 cm x 2.7 cm
390 g
United Kingdom
NETGEAR lifetime warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Fast Ethernet
Ports
8 x 10/100
Performance
Bandwidth: 1.6 Gbps
2K entries
Status Indicators
Port status, power, link/activity
8 x 100Base-TX RJ-45
External power adapter
Wall mounting kit
MTBF
4,200,000 hours
C-Tick, cUL, EN 60950, UL 1950, FCC Part 15 Class B, IEC 950, EN 55022/CISPR 22 Class A, RU EAC
United Kingdom
15.8 cm
10.3 cm
2.7 cm
390 g
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years , Technical support - lifetime
90% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Type: Fast Ethernet
Ports: 8
Managed: No
POE: No
Brand: NETGEAR
