NetGear 6PT PSAFE Dual WAN VPN FWLL
Quicklinx: B63FWS00 Mfr#: FVS336G-300EUS
NETGEAR ProSAFE business-class VPN Firewalls are high performing routers that deliver Stateful Packet Inspection (SPI), Virtual Private Network (VPN), Network Address Translation (NAT), AES and 3DES Encryption, Denial of Service (Dos) protection and provide full secure network access between headquarter locations, remote/branch offices and remote workers. This makes it the ideal solution to provide businesses with the essential network security needed to stop unwanted intrusions.
  • Secure
    NETGEAR ProSAFE VPN Firewalls provide both secure IPsec site-to-site tunnels and IPsec secure access for remote clients and also support client-less SSL VPN as well as secure L2TP and PPTP connections. Employing a true SPI firewall with customizable firewall rules, this VPN router is a high-performance, SNMP-manageable, network solution that furnishes multidimensional security including denial-of-service (Dos) protection, stateful packet inspection (SPI), URL keyword filtering, logging, reporting, and real-time alerts.
  • Flexible
    ProSAFE VPN Firewalls work perfectly with ISP modems, including cable or DSL broadband connections. Wireless-N connectivity and Gigabit LAN/WAN ports keep your data moving at top speed and a configurable DMZ port allows for flexible server deployment. With Network Address Translation (NAT) routing and classical routing, all the users in your small office can access your broadband connection at the same time. VLAN support allows for guest networks plus better network segmentation and IPv6 support will enable you to future proof your network.
  • Reliable
    Models with multiple WAN ports can operate in either a load-balancing or fail-over configuration. The load balancing configuration enables maximum throughput by utilizing WAN connections to distribute traffic across two broadband connections, possibly with different ISP providers. Alternatively, a second WAN port may be configured as a failover connection in case the primary connection fails, for another method of providing high reliability.
NETGEAR ProSafe FVS336Gv3 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Performance
VPN throughput (3DES IPSec): 78 Mpps
IPSec VPN tunnels: 25 , Virtual interfaces (VLANs): 254 , Concurrent connections: 10000 , SSL VPN tunnels: 10
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, IPSec, PPPoE, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
Telnet, SNMP 2c, HTTP, HTTPS
DMZ port, NAT support, VPN support, PAT support, LDAP support, interrupt status port (ISP), VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, ALG support, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, Quality of Service (QoS), DHCP server, DNS proxy, port forwarding, IPv4 support, port triggering, DHCP relay, DHCP client, static routing, Mobile Internet Auto-Configuration Solution (MIAS), SNMP support, Type of Service (ToS)
IEEE 802.1Q, UPnP
25.4 cm x 17.8 cm x 3.96 cm
1.7 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
Triple DES, MD5, AES, IKE, SHA-1, TLS 1.0, SSL 3.0, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, X.509 certificates, LDAP, Active Directory
IEEE 802.1Q, UPnP, cUL, CCC, AES, RoHS, X.509 v3, FCC Part 15 A, VPNC certified, LVD, EMI, China RoHS
1 x 500 MHz
RAM
128 MB SDRAM
Flash Memory
32 MB
WAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
1 x network cable
Europe
Software Included
Drivers & Utilities
25.4 cm
17.8 cm
3.96 cm
1.7 kg
45 °C
90% (non-condensing)
