Each port of this NETGEAR ProSAFE switch automatically detects which speed is needed by the connected device and provides the adequate speed.
Robust performance
With a bandwidth capacity of 100 Gbps, the NETGEAR XS505M switch ensures efficient handling of data across networks, making it ideal for environments requiring high-speed data transmission. -
Enhanced connectivity
Equipped with four RJ-45 connectors and one SFP+ connector, this switch offers versatile connectivity options for a variety of network configurations, supporting both copper and fiber connections. -
Durable design
The metal housing and inclusion of a rack mounting kit underscore the NETGEAR XS505M's durability and adaptability to various installation environments, from desktops to data centers. -
Energy efficient
Featuring Energy-Efficient Ethernet (EEE) and a single fan design, the switch optimizes power usage without compromising on performance, making it an eco-friendly addition to any network setup. -
Advanced network management
Support for Quality of Service (QoS), Class of Service (CoS), and Weighted Round Robin (WRR) enables precise traffic prioritization, ensuring critical data is transmitted efficiently across the network.
- NETGEAR XS505M - switch - 5 ports - unmanaged - rack-mountable
- Switch - 5 ports - unmanaged
- Enclosure Type
- Rack-mountable
- Subtype
- 10 Gigabit Ethernet
- Ports
- 4 x 10 Gigabit Ethernet + 1 x 10 Gigabit SFP+
- Performance
- Bandwidth: 100 Gbps
- Capacity
- Priority queues: 8
- MAC Address Table Size
- 2K entries
- Jumbo Frame Support
- 9KB
- DiffServ support, store and forward, QoS, 128KB packet buffer, CoS, metal housing, 1 fan, EEE, WRR
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az, IEEE 802.3bz
- Power
- AC 120/230 V (50 - 60 Hz)
- 32.8 cm x 16.9 cm x 4.32 cm
- 1.38 kg
- Localisation
- United Kingdom, Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Ports
- Performance
- Capacity
- 2K entries
- 9KB
- Status Indicators
- Power, fan, link/activity/speed
- 4 x 10GBase-T RJ-45 , 1 x 10GBase-X SFP+
- Power Device
- Internal power supply
- Voltage Required
- 22.5 watt
- Rack Mounting Kit
- Included
- MTBF
- 1093237 hours
- Plug and Play, VCCI, BSMI, ICES-003, EN55024, AS/NZS 60950-1, UL 60950-1, KCC, KC, CNS 13438, EN 55024:2010, FCC CFR47 Part 15 B Class B, AS/NZS CISPR 32 Class B, CNS 14336-1, VCCI V-4/2012.04, VCCI V-3/2015.04 Class B, ANSI C63.4-2014, CISPR 32, EN 55032, EN 55032:2012+AC:2013 Class B, ICES-003:2016 issue 6 Class B, EN 61000-3-2:2014 Class B, EN 6100-3-3:2013, sDoC, CB 60950-1, LVD 60950-1
- Localisation
- 32.8 cm
- 16.9 cm
- 4.32 cm
- 1.38 kg
- Limited warranty - replacement - lifetime - response time: next business day ¦ Technical support - lifetime
- 0 °C
- 50 °C
- 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
