NETGEAR 5Pt 10G/Multigigabit Unmanaged Swch
Quicklinx: D9Q6WS00 Mfr#: XS505M-100EUS
Type: 10 Gigabit Ethernet
Ports: 5
Managed: No
Select:
£329.07 ex VAT
£394.88 inc VAT
Each port of this NETGEAR ProSAFE switch automatically detects which speed is needed by the connected device and provides the adequate speed.
  • Robust performance
    With a bandwidth capacity of 100 Gbps, the NETGEAR XS505M switch ensures efficient handling of data across networks, making it ideal for environments requiring high-speed data transmission.
  • Enhanced connectivity
    Equipped with four RJ-45 connectors and one SFP+ connector, this switch offers versatile connectivity options for a variety of network configurations, supporting both copper and fiber connections.
  • Durable design
    The metal housing and inclusion of a rack mounting kit underscore the NETGEAR XS505M's durability and adaptability to various installation environments, from desktops to data centers.
  • Energy efficient
    Featuring Energy-Efficient Ethernet (EEE) and a single fan design, the switch optimizes power usage without compromising on performance, making it an eco-friendly addition to any network setup.
  • Advanced network management
    Support for Quality of Service (QoS), Class of Service (CoS), and Weighted Round Robin (WRR) enables precise traffic prioritization, ensuring critical data is transmitted efficiently across the network.
NETGEAR XS505M - switch - 5 ports - unmanaged - rack-mountable
Switch - 5 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
4 x 10 Gigabit Ethernet + 1 x 10 Gigabit SFP+
Performance
Bandwidth: 100 Gbps
Priority queues: 8
MAC Address Table Size
2K entries
Jumbo Frame Support
9KB
DiffServ support, store and forward, QoS, 128KB packet buffer, CoS, metal housing, 1 fan, EEE, WRR
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az, IEEE 802.3bz
AC 120/230 V (50 - 60 Hz)
32.8 cm x 16.9 cm x 4.32 cm
1.38 kg
United Kingdom, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
Bandwidth: 100 Gbps
Priority queues: 8
2K entries
Jumbo Frame Support
9KB
Status Indicators
Power, fan, link/activity/speed
4 x 10GBase-T RJ-45 , 1 x 10GBase-X SFP+
Internal power supply
22.5 watt
Rack Mounting Kit
Included
MTBF
1093237 hours
Plug and Play, VCCI, BSMI, ICES-003, EN55024, AS/NZS 60950-1, UL 60950-1, KCC, KC, CNS 13438, EN 55024:2010, FCC CFR47 Part 15 B Class B, AS/NZS CISPR 32 Class B, CNS 14336-1, VCCI V-4/2012.04, VCCI V-3/2015.04 Class B, ANSI C63.4-2014, CISPR 32, EN 55032, EN 55032:2012+AC:2013 Class B, ICES-003:2016 issue 6 Class B, EN 61000-3-2:2014 Class B, EN 6100-3-3:2013, sDoC, CB 60950-1, LVD 60950-1
32.8 cm
16.9 cm
4.32 cm
1.38 kg
Limited warranty - replacement - lifetime - response time: next business day ¦ Technical support - lifetime
50 °C
95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 5
Managed: No
Brand: NETGEAR
