5 Gigabit Ethernet ports
4 PoE+ ports with 63W total power budget
Simple plug-and-play setup with no software to install or configuration needed
Supports desktop or wall mount placement
Silent operation ideal for noise sensitive environment
Efficient power management
The GS305P features a robust 55.5 W PoE budget, providing flexible power options to power devices such as IP cameras, VoIP phones, and wireless access points directly through the network cables, eliminating the need for additional power supplies and reducing clutter. -
Versatile connectivity options
With five 10/100/1000 Mbps ports, including four PoE ports, this switch offers ample bandwidth and flexibility to support a variety of network configurations and devices, ensuring a high-speed and reliable network connection for all connected devices. -
Easy installation
Designed for convenience, the GS305P supports Plug-and-Play installation with no software or configuration required. Its compact form factor allows for desktop or wall-mounted setup, making it an ideal choice for small to medium-sized businesses or home offices.
- NETGEAR GS305P - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000 (4 PoE)
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 55.5 W
- Fanless
- 3-year warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 55.5 W
- Fanless
- Status Indicators
- Power, PoE, link/activity
- 4 x 1000Base-T RJ-45 PoE , 1 x 1000Base-T RJ-45
- Plug and Play
- Limited warranty - 3 years
