NETGEAR 5P AC2300 Wifi Router With MU-MIMO
Quicklinx: CZPWWS00 Mfr#: R7000P-100UKS
  • IEEE 802.11n
£146.24 ex VAT
£175.48 inc VAT
NETGEAR Nighthawk AC2300 Smart Wi-Fi Router was built to handle all your high-bandwidth online activities with features that will keep you connected at top speeds. With the powerful 1GHz dual-core processor and Dynamic QoS, Nighthawk can prioritize bandwidth to your game so other devices on the network don't slow down your connection. Enjoy uninterrupted video streaming with limited buffering for streaming applications like YouTube, Netflix, and others. And with features like high performance external antennas, and Beamforming+, you can enhance your mobile speeds by up to 100%, so you can roam freely throughout your home without fear of slow or dropped connections.
  • Built for gaming, streaming and mobility
  • Multi-user MIMO (MU-MIMO)
    Using Multi-User MIMO technology, NETGEAR routers can stream data to multiple devices simultaneously. With MU-MIMO, your Wi-Fi network can deliver faster throughput to every MU-MIMO connected device. That means faster downloads and smoother streaming for your devices.
  • Dynamic quality of service
    If you like gaming and streaming videos, then you'll benefit from Dynamic Quality of Service (QoS). Dynamic QoS resolves Internet traffic congestion when you have competing Internet demands at home. Dynamic QoS identifies your online activities by application and device, and then utilizes bandwidth allocation, and traffic prioritization techniques, to automatically allocate more bandwidth to latency sensitive applications like online gaming and video streaming, while ensuring that lower priority applications continue to work.
  • Simple and secure cloud storage
    Access and share your files stored on a USB Drive through NETGEAR ReadyCLOUD USB Access. Simply plug your USB hard drive into your NETGEAR Nighthawk Wi-Fi Router to create secure personal cloud storage. Enjoy the convenience and accessibility of Google Drive and Dropbox without the fees, storage limitations, or privacy concerns.
NETGEAR Nighthawk PR7000 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1625 Mbps
NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, Quality of Service (QoS), FTP server, ReadySHARE, 3T3R MIMO technology, Beamforming+, MU-MIMO technology, Smart Connect, ReadyCLOUD, Circle Smart Parental Controls
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
28.5 cm x 18.45 cm x 5 cm
750 g
UNIX, Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1625 Mbps
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
1 GHz
RAM
256 MB
Flash Memory
128 MB
Line Properties
Line Coding Format
1024 QAM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A , Antenna: 3 x
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
1 x network cable
United Kingdom
28.5 cm
18.45 cm
5 cm
750 g
Type: Wireless router
Standards: Ethernet
Standards: IEEE 802.11b
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11n
Standards: IEEE 802.11g
Standards: Gigabit Ethernet
Standards: IEEE 802.11ac
Speed: 1625Mbps
Brand: NETGEAR
