NETGEAR 5P AC1200 FE Router
Quicklinx: CZPTWS00 Mfr#: R6120-100UKS
  • IEEE 802.11n
£38.26 ex VAT
£45.91 inc VAT
Speed makes video streaming better. Speed makes online gaming more fun. Speed makes all your devices really go. And any place you need speed, with NETGEAR you got it. Fast download speeds up to 1200 Mbps. Wi-Fi with dual band technology providing whole home coverage. Everything you need for a fast connected home.
Homes come in all shapes and sizes. The AC1200 Dual Band Wi-Fi Router provides Wi-Fi connectivity throughout your home for all your Internet-enabled devices.
Stay connected - with your devices, your media, and your friends. Simultaneous Dual Band Wi-Fi provides two separate Wi-Fi networks - 2.4 GHz for legacy devices and 5 GHz which is less interference-prone for media streaming.
  • Enhanced security
    Equipped with WPA-PSK and WPA2-PSK encryption algorithms, this NETGEAR R6120 wireless router ensures your network remains secure against unauthorized access.
  • Versatile connectivity
    With support for Ethernet, Fast Ethernet, and Wi-Fi 5 (802.11a/b/g/n/ac), the router offers flexible options for both wired and wireless connections, catering to a variety of devices and setups.
  • Dual-band advantage
    The 2.4 GHz and 5 GHz Wi-Fi bands provide a dual-band connection, optimizing network performance by minimizing interference and maximizing speed for your online activities.
  • Convenient sharing features
    ReadySHARE technology allows for easy sharing of a USB storage device across your network, making it simple to access and share files, photos, and music with other devices on your home network.
  • Easy management
    Featuring a 4-port switch and one USB 2.0 port, this router simplifies the connection of multiple devices and the management of your home network, offering a seamless user experience.
NETGEAR R6120 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Network / Transport Protocol
PPPoE, DHCP, SMB
Routing Protocol
RIP-1, RIP-2
Auto-sensing per device, DHCP support, NAT support, dynamic DNS server, IPv6 support, ReadySHARE, dual band, Circle Smart Parental Controls
IEEE 802.11, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
18.5 cm x 13.65 cm x 4.6 cm
250 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
PPPoE, DHCP, SMB
Routing Protocol
RIP-1, RIP-2
Encryption Algorithm
WPA-PSK, WPA2-PSK
IEEE 802.11, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC Part 15 Class B
RAM
64 MB
Flash Memory
16 MB
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 5 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
1 x network cable
18.5 cm
13.65 cm
4.6 cm
250 g
Type: Wireless router
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11b
Standards: IEEE 802.11ac
Speed: 1200Mbps
Brand: NETGEAR
