NETGEAR 550W 100-240VAC Power Supply Unit
Quicklinx: CDW6WS00 Mfr#: APS550W-100NES
£298.73 ex VAT
£358.47 inc VAT
NETGEAR ProSAFE Modular Power Supply Unit 550W AC (APS550W) is compatible with select Managed Switches such as M4300-28G-PoE+ (GSM4328PA) and M4300-52G-PoE+ (GSM4352PA). These M4300 series switches come with one PSU pre-installed. Another APS550W in second PSU bay can be combined for 1+1 power redundancy or 1+1 power expansion.
  • Robust power supply
    Designed to meet the demands of network hardware, the NETGEAR APS550W offers 550 watts of power. This ensures your network infrastructure operates efficiently without the risk of power shortages.
  • Versatile compatibility
    With an input connector type of power IEC 60320 C14, the NETGEAR APS550W is built to support a wide range of network hardware. This versatility ensures seamless integration into existing network setups, making it a suitable choice for system upgrades or expansions.
NETGEAR APS550W - power supply - redundant - 550 Watt
Power supply - redundant - internal
Europe, Americas
Input Voltage
AC 110-240 V
Power Capacity
550 Watt
Input Connectors
Power IEC 60320 C14
5-year warranty
NETGEAR M4300-28G-PoE+ (550 Watt)
Europe, Americas
Input Voltage
AC 110-240 V
Input Connectors
Power IEC 60320 C14
Power Capacity
550 Watt
Limited warranty - 5 years
Type: Power Supplies
Brand: NETGEAR
