Brand
NETGEAR 50PT Gigabit Web Managed Plus Switch
Quicklinx: D9Q1WS00 Mfr#: GS750E-100EUS
Type: Gigabit Ethernet
Ports: 50
Managed: Yes
£214.24 ex VAT
£257.08 inc VAT
The NETGEAR GS750E ProSafe 48-Port Smart Plus Gigabit Switch meets this growing need by providing fundamental network features that will help optimise performance of business networks.
NETGEAR Plus GS750E - switch - 50 ports - smart - rack-mountable
Switch - 50 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x Gigabit SFP
Performance
Bandwidth: 100 Gbps , Packet forwarding rate: 11.9 Mfps , Latency (10 Gbps): < 32 µs , Latency (100 Mbps): < 6 µs , Latency (1 Gbps): < 4 µs
VLANs supported: 4000 , Priority queues per port: 8
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
HTTP, TFTP
DHCP support, trunking, VLAN support, IGMP snooping, port mirroring, firmware upgradable, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Jumbo Frames support, fanless, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, loop prevention, Multicast filtering function, Type of Service (ToS), DiffServ Code Point (DSCP) support, 1.5MB packet buffer, cable test, Link Aggregation, Weighted Deficit Round Robin (WDRR), Voice VLAN, Denial of Service (DoS) protection
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 120/230 V (50 - 60 Hz) 1 A
44 cm x 20.4 cm x 4.3 cm
3.25 kg
United Kingdom, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
HTTP, TFTP
Status Indicators
Port transmission speed, power, link/activity
48 x 1000Base-T RJ-45 , 2 x SFP
Internal power supply
Electric Current Required
1 A
Rack Mounting Kit
Included
MTBF
1,031,177 hours
Plug and Play, EN 61000-3-2, ICES-003, EN 61000-3-3, CISPR 22, CB, AS/NZS 60950-1, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 61010-1, KC, ANSI C63.4, EAC, CNS 13438, EN 55024:2010, EN 55024 Class A, VCCI V-4/2012.04, VCCI V-3/2015.04
44 cm
20.4 cm
4.3 cm
3.25 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 50
Managed: Yes
Brand: NETGEAR
