NETGEAR 5-Port GS308 Gigabit Ethernet Unmanaged  Network Switch
Quicklinx: GCZCWS00 Mfr#: GS308-300UKS
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: [N/A]
Managed: No
POE: No
23 In Stock
£20.75 ex VAT
£24.90 inc VAT
The NETGEAR 300 Series Unmanaged Switches provide easy and affordable network connectivity to home and small offices. They are easy to use and reliable. With these Plug-and-Play switches, you can expand your network connections to multiple devices instantly. The 300 series also support the efficient use of energy, helping you save power and money.
  • Energy efficient design
    With the integration of Energy Efficient Ethernet (IEEE 802.3az) technology, this NETGEAR GS308v3 switch optimizes power usage to lower operational costs without compromising performance.
  • Seamless connectivity
    Featuring 8 RJ-45 connectors supporting 1000Base-T for Gigabit Ethernet, this switch ensures high-speed connectivity and seamless network integration for up to 8 devices.
  • Robust performance
    Auto-negotiation and auto-uplink (auto MDI/MDI-X) capabilities allow for effortless network optimization, while fanless design ensures silent operation, making it ideal for noise-sensitive environments.
NETGEAR GS308v3 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps , Forwarding performance (64-byte packet size): 1448000 pps
Packet buffer size: 128
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS, fanless, Energy Efficient Ethernet, SOHO, WRR
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
15.8 cm x 10.1 cm x 2.9 cm
390 g
3-year warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Power, link/activity
8 x 1000Base-T RJ-45
External power adapter
3.04 Watt
Power Consumption Stand by
0.36 Watt
MTBF
3,711,898 hours
Plug and Play, IC Class B, VCCI, CB, FCC Part 15 B, CCC, LVD, KC, RCM
15.8 cm
10.1 cm
2.9 cm
390 g
Limited warranty - 3 years
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 8
Managed: No
POE: No
Brand: NETGEAR
