NETGEAR 5-Port 10/100 Switch
Customer rating: 5.0* (Write a review)
Quicklinx: 22ZKWS00 Mfr#: FS605UK
Hang on - your network will soar when it's hooked up to NETGEAR's FS605!
This powerful plug-and-play switch connects at 10 or 100 Mbps and makes it easy to link as many as five computers or peripherals to your Ethernet network.
You'll experience maximum performance for 10 or 100 Mbps devices with five ports that automatically sense the correct speed while Auto Uplink on the ports adjusts for the different types of Ethernet cables. The FS605's sleek case has lights on the front for easy monitoring. Installation into your home network couldn't be simpler and, once powered on, it begins cool and silent operation - without an internal fan.
Auto Uplink™ technology automatically adjusts to suit all your Ethernet cables
Every port automatically senses the right speed and duplex mode
Low power consumption, enabling these switches to run cool without a fan
Works with PCs, Macs, servers, printers & virtually any Ethernet device
Attractive, compact platinum design blends seamlessly into your home decor
Network Connectivity: 5 RJ-45 ports for 10BASE-T and 100BASE-TX
Status LEDs: Power, Speed and activity on each port
NETGEAR FS605 - switch - 5 ports
Switch - 5 ports
Subtype
Fast Ethernet
Ports
5 x 10/100
MAC Address Table Size
1K entries
Flow control, full duplex capability, MDI/MDI-X switch, auto-negotiation, auto-uplink (auto MDI/MDI-X)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3x
17.5 cm x 11.8 cm x 2.8 cm
0.3 kg
Apple MacOS, Novell NetWare, Linux, Microsoft Windows
3-year warranty
Switch - 5 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
5 x 10/100
1K entries
Status Indicators
Port transmission speed, power, link/activity
5 x 100Base-TX RJ-45
External power adapter
3.7 Watt
Mounting Kit
Included
FCC Class B certified, TUV, C-Tick
17.5 cm
11.8 cm
2.8 cm
0.3 kg
Technical support - phone consulting - response time: 24/7 hours a day / days a week , Limited warranty - 3 years , Technical support - e-mail consulting - response time: 24/7 hours a day / days a week
0 - 90%
Customer reviews
Write a review for the NETGEAR 5-Port 10/100 Switch here!
Great Network Switch
Reviewed by Lee Thomas. Review Posted 21/07/2007
Great for extending your network with no hassle.
Just ordered the 4th
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
good value stylish swtich
Reviewed by Anonymous Review Posted 28/11/2003
good switch. nice design.
has mount so you can mount it vertically.
only has data transfer lights (no duplex/full duplex) lights.
apart from that.. no complaints.
running 24/7 no probs for nearly a year.
  • Overall 5*
  • Ease of use 5*
great switch
Reviewed by Anonymous Review Posted 20/05/2004
Top quality switch. I've currently been running it 24/7 for over 6 months with absolutely no problems. Transferred over 20Tb with this switch as part of a 100Mbit campus network. Would strongly recommend.
  • Overall 5*
  • Ease of use 5*
Read all 7 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
