Orbi is an extremely simple and smart way to enjoy high-speed Wi-Fi in every corner of your home. Each add-on Orbi satellite easily expands your Orbi Wi-Fi system to cover an additional 2000 square feet with strong Wi-Fi signals. Tri-band Wi-Fi creates a dedicated wireless connection to your Orbi router and the Internet, so no matter how many devices connect you'll get maximum speed.
Better Wi-Fi everywhere
Take any Wi-Fi device from room to room and Orbi follows with extremely fast Wi-Fi speeds. -
Max Internet speeds
Orbi uses Tri-band Wi-Fi to keep your Internet running at max speeds no matter how many devices connect. -
Your home covered
Add-on to your existing Orbi Wi-Fi system to expand your Wi-Fi coverage an additional 2000 sq.ft. with high-performance AC3000 Wi-Fi. -
Growing with you
Each add-on Orbi satellite expands your high performance Wi-Fi coverage an additional 2000 sq.ft.
- NETGEAR Add-on High-performance AC3000 Tri-band WiFi Satellite - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- Desktop
- RAM
- 512 MB
- Flash Memory
- 4 GB
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- 17.03 cm x 7.89 cm x 22.58 cm
- 890.5 g
- 17.03 cm
- 7.89 cm
- 22.58 cm
- 890.5 g
Processor / Memory / Storage
- RAM
- 512 MB
- Flash Memory
- 4 GB
- Form Factor
- Desktop
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 3 Gbps
- Frequency Band
- 2.4 GHz, 5 GHz
- MU-MIMO technology, beamforming technology, Circle Smart Parental Controls
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- Internal
- Antenna Qty
- 6
- 4 x 1000Base-T - RJ-45 , 1 x USB 2.0
- FCC
