NETGEAR 48 Port GigE Unmanaged Rackmount Switch
Quicklinx: CZPJWS00 Mfr#: GS348-100EUS
Type: Gigabit Ethernet
Ports: 48
Data Transfer Rate: [N/A]
Managed: No
POE: No
£262.11 ex VAT
£314.53 inc VAT
NETGEAR 300 Series Gigabit Ethernet Unmanaged Switches provide easy, reliable, and affordable network connectivity for home and small offices. With these unmanaged plug-and-play switches, you can expand your network connections to multiple devices instantly.
  • Robust performance
    With a bandwidth of 96 Gbps and forwarding performance capable of handling up to 1,448,000 packets per second, this switch ensures smooth data transmission and efficient network traffic management, even during peak times.
  • High capacity
    Equipped with 48 10/100/1000 ports, the NETGEAR SOHO GS348 accommodates a large number of devices, making it a suitable solution for expanding network capacity.
  • Energy efficient
    Features like Energy-Efficient Ethernet (EEE) and a fanless design not only reduce operational costs but also contribute to a quieter, more environmentally friendly workspace.
  • Easy management
    Thanks to its Plug-and-Play setup and quality of service (QoS) features, this switch simplifies network management, automatically prioritizing traffic to ensure critical applications get the bandwidth they need.
  • Durable and reliable
    Designed for both desktop and rack-mountable setups, this switch comes with a rack mounting kit included, offering flexibility in installation and ensuring it fits seamlessly into any office environment.
NETGEAR SOHO GS348 - switch - 48 ports - unmanaged - rack-mountable
Switch - 48 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Performance
Bandwidth: 96 Gbps , Forwarding performance (64-byte packet size): 1448000 packets per second , Latency (64-byte packets): 4 µs
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS, fanless, 1.5MB packet buffer, EEE
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
44 cm x 20.4 cm x 4.32 cm
3.15 kg
3-year warranty
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Performance
16K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Power, link/activity
48 x 1000Base-T RJ-45
Internal power supply
23 Watt
Power Consumption Stand by
8.81 Watt
Rack Mounting Kit
Included
Plug and Play
44 cm
20.4 cm
4.32 cm
3.15 kg
Limited warranty - 3 years
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 48
Managed: No
POE: No
Brand: NETGEAR
