The NETGEAR AC WiFi Business Access Point WAC510 delivers high performance with high client density for enterprises requiring ubiquitous and reliable wireless for all business applications. The WAC510 features Multi-User MIMO (MU-MIMO) to achieve aggregate speeds up to 1.2 Gbps and option to configure as Router or Access Point modes.
Efficient connectivity
With support for Ethernet, Fast Ethernet, and Gigabit Ethernet alongside Wi-Fi 5 capabilities, this device ensures high-speed connectivity across both wired and wireless networks. It's designed to keep pace with the demands of modern businesses and tech-savvy homes. -
Advanced security
Featuring a comprehensive suite of encryption algorithms including WPA, WPA-PSK, WPA2, and WPA2-PSK, alongside multiple authentication methods like EAP and RADIUS, this router provides robust security measures to protect your network from unauthorized access. -
Seamless operation
Boasting a high MTBF of 978,210 hours and operational temperatures ranging from 0°C to 40°C, this device promises reliability and durability in various environments, ensuring continuous operation and minimal downtime. -
Versatile mounting options
Designed for flexibility, it can be mounted on the ceiling, wall, or placed on a desktop, making it suitable for a wide range of spaces and applications. The included mounting kit facilitates easy installation in the desired location. -
Dual-band advantage
The dual-band functionality with 2.4 GHz and 5 GHz Wi-Fi bands allows for a more reliable connection by minimizing interference and congestion, ensuring smoother online experiences for streaming, gaming, and downloading.
- NETGEAR Insight Managed Smart Cloud (WAC510) - wireless router - Wi-Fi 5 - desktop, wall-mountable, ceiling-mountable
- Wireless router
- Packaged Quantity
- 3 (specifications are for single item)
- Enclosure Type
- Desktop, wall-mountable, ceiling-mountable
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
- 2.4 GHz / 5 GHz
- Capacity
- Maximum number of clients: 200
- Bonjour
- Remote Management Protocol
- SNMP 1, SNMP 2c, SSH
- VLAN support, auto-uplink (auto MDI/MDI-X), MAC address filtering, WMM support, ACL support, QoS, LLDP support, rogue access point detection, TPC, band steering, guest access, 2x2:2 MU-MIMO technology, WDS bridge PtP mode, WDS bridge PtMP mode
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2
- 19.732 cm x 19.732 cm x 3.7 cm
- 555.5 g
- Localisation
- Worldwide (excluding United States and Canada)
- Packaged Quantity
- Wireless router
- Enclosure Type
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Capacity
- Bonjour
- Encryption Algorithm
- SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA-PSK, WPA2-PSK
- Authentication Method
- Secure Shell (SSH), RADIUS, Basic Service Set Identifier (BSSID), Extensible Authentication Protocol (EAP)
- Wi-Fi Rating
- AC1300
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2, EN 60950
- Status Indicators
- Power, LAN, link/activity, 2.4/5 GHz
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T (PoE+) - RJ-45 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- 9.3 Watt
- Included Accessories
- Wall mounting kit, ceiling mounting kit
- Mounting Kit
- Included
- MTBF
- 978,210 hours
- Localisation
- 19.732 cm
- 19.732 cm
- 3.7 cm
- 555.5 g
- 0 °C
- 40 °C
- 10 - 90%
