Extend your wired Internet access to any room in your house using your existing electrical wiring. Just plug the Powerline 1000 into any electrical outlet then plug in your device into the adapter. It's that easy. With its high speed and Homeplug AV2 support, the Powerline 1000 adapter is perfect for connecting smart TVs, streaming players, and game consoles.
Reliable networking
Connect multiple adapters to expand your wired network reliably. -
Plug-and-play
Setup in minutes, no need to configure or install software. -
Energy-saving
Automatically powers down when not in use. -
Push-and-Secure
This function encrypts powerline network connections with the touch of a button.
 - NETGEAR Powerline PL1000 + Extra Outlet - powerline adapter kit - wall-pluggable
 - Powerline adapter kit
- Packaged Quantity
 - 2 (specifications are for single item)
- Enclosure Type
 - Wall-pluggable
- Data Link Protocol
 - Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug Green PHY
- Data Transfer Rate
 - 1 Gbps
 - Integrated power socket, Push-and-Secure button
 - IEEE 802.3, HomePlug AV, IEEE 1901
 - 5.8 cm x 4.2 cm x 12 cm
 - 180.4 g
- Localisation
 - United Kingdom
- Packaged Quantity
- Enclosure Type
 - Wall-pluggable
- Connectivity Technology
 - Wired
 - 1 Gbps
 - IEEE 802.3, HomePlug AV, IEEE 1901, Plug and Play
 - LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV
- Power Device
 - Internal power supply
 - 3.57 Watt
- Cables Included
 - 2 x network cable - 2 m
- Localisation
 - United Kingdom
 - 5.8 cm
 - 4.2 cm
 - 12 cm
 - 180.4 g
