NETGEAR 28-port Managed Gigabit POE+ Smart Switch
Quicklinx: DWDQWS00 Mfr#: GS728TP-200EUS
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE+
Hurry, only 1 left in stock!
£222.34 ex VAT
£266.80 inc VAT
The ProSafe Gigabit stackable smart switch family is unique in delivering the scalability, reliability, and performance growing small and medium-sized businesses need in an affordable and easy-to-manage package. This stackable smart switch offers more flexibility and scalability that will make it easier and non-interruptive for growing businesses to expand their network capacity.
  • Designed for converged network, big or small
    Gigabit Speed with all ports capable of support either PoE or PoE+. Auto Voice VLAN for fast and reliable deployment of VoIP. Auto Video VLAN, following the same concept of Auto Voice, help speed up your deployment of IP-based surveillance system. Static routing, helps to route internal traffic for more efficient use of network resources. IGMP and MLD snooping, providing advanced multicast filtering.
  • Build a future-proof network with NETGEAR
    Solid performance with non-blocking architecture, 8K MAC addresses, 256 VLANs, 480 shared ACL entries, 32static routes, and 1,024 Multicast Groups. Comprehensive IPv6 supporting management, QoS and ACL, ensuring investment protection and a smooth migration to IPv6-based network. PoE+ support on all models with GS728TPP support PoE+ on all ports, providing flexibility in the future to add power-hungry devices such as video phone, PTZ camera and 11ac Wireless APs into the network. 4 dedicated SFPs, not only providing fiber uplinks, but also uplink redundancy and failover, improving reliability and availability for network virtualization. Energy Efficient Ethernet (IEEE802.3az) support for more energy saving in the future when more EEE-compliant end devices come to market. Advanced QoS with IPv4/IPv6 ingress traffic filtering (ACLs) and prioritization (QoS - DiffServ). Dynamic VLAN assignment for easy user authentication and location-independent access to network.
  • Network development made easy
    Auto Voice VLAN for easy development of VoIP. Auto Video for simple deployment of IP Surveillaince. ACL Wizard for a guided tour to set up your network access control. Smart Control Center, a powerful tool for multi-switch discovery, deployment, monitoring and firmware upgrade. PoE Timer for scheduling on/off time of your PoE powered devices. With PD and PoE capability on the same device, GS516TP make network switch deployment truly free from AC power outlet. It provides maximum flexibility for network build-up, modifications and re-layout.
NETGEAR Smart GS728TP - v2 - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - L3 - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
190 W
Performance
Switch fabric speed: 56 Gbps , Forwarding performance (64-byte packet size): 41.67 Mpps
ACL: 100 , ARP entries: 512 , VLANs supported: 256 , IPv4 routes (static): 32 , IPv6 routes (static): 32 , IGMP multicast groups: 512
MAC Address Table Size
16K entries
Jumbo Frame Support
10KB
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
DHCP support, IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, DHCP snooping, QoS, MLD snooping, DAI, DHCP relay, LACP, DHCP client, MVR, GARP, GVRP, ToS, DSCP support, 2 fans, 1.5MB packet buffer, cable test, ICMP IRDP, IGMP querier, Voice VLAN, Private VLAN, Guest VLAN, DoS protection, WRR, Auto VoIP, MAC lockdown
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 25.7 cm x 4.32 cm
3.78 kg
Europe
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
190 W
Performance
16K entries
Jumbo Frame Support
10KB
Routing Protocol
Static IP routing
Encryption Algorithm
TLS
Authentication Method
RADIUS, TACACS+
1: 700 MHz
RAM
128 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, PoE, link/activity
24 x 10/100/1000 Base-T RJ-45 PoE+ , 4 x 1000Base-X SFP , 1 x USB
Internal power supply
Installed Qty
1
Rack Mounting Kit
Included
MTBF
1,250,365 hours
EN 60950, EN55024, CSA 22.2 No. 950, CB, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A, FCC CFR47 Part 15 B Class A, IEC 950, ANSI C63.4-2014, EN 55022/CISPR 22 Class A, ICES-003:2016 issue 6 Class A, AS/NZS CISPR22:2009+A1:2010 Class A, AN/NZS 60950.1:2015, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe
44 cm
25.7 cm
4.32 cm
3.78 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 24
Managed: Yes
POE: PoE+
Brand: NETGEAR
