NETGEAR ProSAFE Modular Power Supply Unit 250W AC (APS250W) is compatible with select Managed Switches such as M4300-8X8F (XSM4316S), M4300-12X12F (XSM4324S) and M4300-24X24F (XSM4348S). These M4300 series switches come with one PSU pre-installed. Another APS250W in full-width models second PSU bay can be combined for 1+1 power redundancy or 1+1 power expansion.
Efficient power supply
Designed to meet the demands of network hardware, the APS250W ensures a steady and reliable power supply, providing 250 W of power. This feature ensures that your network equipment will operate efficiently, minimizing downtime and maintaining productivity. -
Versatile compatibility
The NETGEAR APS250W is engineered for broad compatibility with network hardware, making it an ideal choice for a wide range of network infrastructures. Its use of a standard power IEC 60320 C14 input connector type further enhances its versatility, ensuring easy integration into existing setups.
- NETGEAR APS250W - power supply - redundant - 250 Watt
- Power supply - redundant - internal
- Localisation
- Europe, Americas
- Input Voltage
- AC 110-240 V
- Power Capacity
- 250 Watt
- Input Connectors
- Power IEC 60320 C14
- 5-year warranty
- Designed For
- NETGEAR M4300-12X12F (250 Watt), M4300-24X (250 Watt), M4300-24X24F (250 Watt), M4300-48X (250 Watt), M4300-8X8F (250 Watt)
- Localisation
- Europe, Americas
- Input Voltage
- AC 110-240 V
- Input Connectors
- Power Capacity
- 250 Watt
- Limited warranty - 5 years
- Designed For
