NETGEAR 250W 100-240VAC Power Supply Unit
Quicklinx: CDW4WS00 Mfr#: APS250W-100NES
Hurry, only 1 left in stock!
£168.22 ex VAT
£201.86 inc VAT
NETGEAR ProSAFE Modular Power Supply Unit 250W AC (APS250W) is compatible with select Managed Switches such as M4300-8X8F (XSM4316S), M4300-12X12F (XSM4324S) and M4300-24X24F (XSM4348S). These M4300 series switches come with one PSU pre-installed. Another APS250W in full-width models second PSU bay can be combined for 1+1 power redundancy or 1+1 power expansion.
  • Efficient power supply
    Designed to meet the demands of network hardware, the APS250W ensures a steady and reliable power supply, providing 250 W of power. This feature ensures that your network equipment will operate efficiently, minimizing downtime and maintaining productivity.
  • Versatile compatibility
    The NETGEAR APS250W is engineered for broad compatibility with network hardware, making it an ideal choice for a wide range of network infrastructures. Its use of a standard power IEC 60320 C14 input connector type further enhances its versatility, ensuring easy integration into existing setups.
NETGEAR APS250W - power supply - redundant - 250 Watt
Power supply - redundant - internal
Europe, Americas
Input Voltage
AC 110-240 V
Power Capacity
250 Watt
Input Connectors
Power IEC 60320 C14
5-year warranty
NETGEAR M4300-12X12F (250 Watt), M4300-24X (250 Watt), M4300-24X24F (250 Watt), M4300-48X (250 Watt), M4300-8X8F (250 Watt)
Europe, Americas
Input Voltage
AC 110-240 V
Input Connectors
Power IEC 60320 C14
Power Capacity
250 Watt
Limited warranty - 5 years
Type: Power Supply
Brand: NETGEAR
