IP telephony, Wireless or Video-Surveillance deployments may require higher PoE+ density in wiring closets. This 24-port PoE+ platform is 802.3af full power – with supplemental 802.3at full power capacity – yet affordable when compared to typical competitive solutions with even less PoE budget. When associated to GSM7212F, PoE deployments can be much Smarter with the right number of PoE ports – whenever and wherever you want.
Intelligent Edge
Combining superior resiliency and advanced security even far from the wiring closet, the switches provide comprehensive Layer 2 and Lite Layer 3 switching, including 16K MAC table size, 64 routing interfaces and 16 static routes. -
Unified Communications - Voice over IP
The NETGEAR ProSafe "Intelligent Edge" simplifies converged data deployments with state-of-the-art capabilities. CoS Layer 2 prioritization and DiffServ Layer 3 & 4 policies allow for 1Kbps ingress and egress TCP/UDP granularity. LLDP-MED (Media Endpoint Discovery) automatically configures IP phones QoS and VLAN settings. -
Unified Communications - video streams
IGMP filtering and querier ensure multicast streams are only delivered to interested receivers, preventing flooding even without a dedicated multicast router. When receivers are in different VLANs, Multicast VLAN registration (MVR) uses a dedicated multicast VLAN to forward multicast streams and avoid duplication for clients in different VLANs. -
Outstanding value
With its high-value price point, industry-standard command line interface (CLI) and single-pane-of-glass NMS200 management platform (mass-configuration support), NETGEAR ProSafe "Intelligent Edge" yields a high return on investment.
- NETGEAR M4100-24G-PoE+ - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L2+ - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+) + 4 x shared SFP
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Switching capacity: 48 Gbps
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
- VLAN support, DiffServ support, IPv6 support, STP support, RSTP support, MSTP support, QoS, Jumbo Frames support, DHCP server, PoE+, IPv4 support, LACP, DHCP client
- IEEE 802.3af, IEEE 802.1x, IEEE 801.1p
- 44 cm x 20.5 cm x 4.3 cm
- 3.7 kg
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Performance
- 8K entries
- Max Units In A Stack
- 8
- Routing Protocol
- Static IP routing
- Authentication Method
- RADIUS, TACACS+
- 24 x 10Base-T/100Base-TX/1000Base-T RJ-45 PoE+ , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB , 4 x SFP (mini-GBIC) - SFP
- Power Device
- Internal power supply
- 38.5 watt
- MTBF
- 239,032 hours
- 44 cm
- 20.5 cm
- 4.3 cm
- 3.7 kg
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.16 |
