Today's growing businesses demand and rely more on their network to carry out mission-critical business activities. Companies are putting more network traffic and applications on their Ethernet infrastructure. For example, the increasing deployments of VoIP phones and IP cameras require more than simple Plug-and-Play connectivity. It needs the network intelligence to separate the voice and video traffic from data, and prioritize them accordingly. Additionally, Internet-based applications such as Hotmail and Google Calendaring have made keeping the network up a business-critical need. However, companies do not necessarily have more money or advanced training to deal with complex managed switches. NETGEAR's ProSafe Plus switches meet this growing need by providing fundamental network features that will help optimize the performance of business networks. ProSafe Plus switches also offer traffic monitoring for users to observe traffic behavior. If there are connectivity issues, these switches can identify and even locate connection problems via cable diagnostic test. To optimize traffic through the switches, ProSafe Plus switches offer both port and tag-based prioritization to keep latency-sensitive traffic moving ahead of less critical packets. Also, ProSafe Plus switches offer port and 802.1Q-based VLAN as a means of improving security and network performance. ProSafe Plus switches are an upgrade from the Plug-and-Play unmanaged switch, delivering great value for empowering your network, delivering great value to the end user.
Enhanced connectivity
With 24 RJ-45 connectors supporting 1000Base-T for high-speed Gigabit Ethernet, the NETGEAR Plus JGS524PE ensures efficient connectivity and network performance. The inclusion of Power over Ethernet (PoE) across 12 ports simplifies network installation and maintenance by eliminating the need for additional power cables. -
Robust security features
The switch is equipped with advanced security measures including DoS attack prevention, broadcast storm control, and IGMP snooping. These features work together to protect the network from unauthorized access and ensure uninterrupted service. -
Optimized network performance
Quality of Service (QoS) and flow control capabilities allow for prioritization of network traffic, ensuring that critical applications receive the bandwidth they need. Port mirroring further aids in network troubleshooting and monitoring, making it easier to identify and resolve issues. -
Flexible installation options
Designed for versatility, the NETGEAR Plus JGS524PE can be placed on a desktop or mounted in a rack, providing flexibility in setup based on your space requirements and preferences. -
Efficient power management
With a total PoE budget of 100 W, this switch can power multiple devices through its Ethernet cables, reducing clutter and saving on energy costs. The internal power supply ensures a reliable power source for the switch and connected devices.
- NETGEAR Plus JGS524PE - switch - 24 ports - smart - rack-mountable
- Switch - 24 ports - smart
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 12 x 10/100/1000 (PoE) + 12 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 100 W
- Performance
- Bandwidth: 48 Gbps
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9000 bytes
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Flow control, IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, QoS, Jumbo Frames support, DHCP client, Energy Efficient Ethernet, 768KB packet buffer, SP, ToS, cable test, Link Aggregation, 1 fan, WRR, port trunking
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
- 32.8 cm x 17 cm x 4.3 cm
- 1.84 kg
- Localisation
- Europe
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 100 W
- Performance
- 16K entries
- 9000 bytes
- Routing Protocol
- Status Indicators
- Port transmission speed, power, PoE, link/activity, fan
- 12 x 1000Base-T RJ-45 , 12 x 1000Base-T RJ-45 PoE
- Power Device
- Internal power supply
- Rack Mounting Kit
- Included
- MTBF
- 643,506 hours
- VCCI, C-Tick, cUL, EN 60950, EN55022, UL 1950, EN55024, CSA 22.2 No. 950, CISPR 22, EN50082-1, CCC, FCC Part 15, IEC 950
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 32.8 cm
- 17 cm
- 4.3 cm
- 1.84 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.96 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.76 |
