NETGEAR 200W External Power Supply Unit
Quicklinx: F63LWS00 Mfr#: EPS200W-100UKS
£62.18 ex VAT
£74.61 inc VAT
Future-proof your PoE budget. Increase or decrease your PoE budget anytime by simply upgrading your switch power supply, without having to purchase a new switch. Select NETGEAR Gigabit Ethernet Unmanaged Switches include a built-in PoE power selector lever, which lets you connect a compatible power adapter to increase or decrease the PoE power available on the switch.
NETGEAR 200W External Power Supply Unit (EPS200W) - power adapter - 200 Watt
Power adapter - external
United Kingdom
Output Voltage
54 V
Power Capacity
200 Watt
United Kingdom
Output Voltage
54 V
Max Electric Current
3.7 A
Power Capacity
200 Watt
Power cable - detachable
Limited warranty - 2 years , Technical support - 90 days
Brand: NETGEAR
