Compatible with M4300-96X models (XSM4396K0, XSM4396K1). The NETGEAR M4300-96X is a 2RU modular switch that comes either empty or pre-populated with 48 SFP+ ports and supporting up to 96-port 10GBASE-T copper (RJ-45) with first 48 ports capable of PoE+, 96-port 10GBASE-X fiber (SFP+), 24-port 40GBASE-X fiber (QSFP+), or a combination. The M4300 family provides world-class services for server and storage interconnect, mid-enterprise edge and SMB core. SDVoE-Ready, M4300 switches streamline AV-over-IP deployments with Zero Touch multicast. Layer 3 feature set includes static, policy-based and dynamic routing as standard.
Enhanced connectivity
The NETGEAR APM402XL features two QSFP+ connectors, providing robust and reliable connectivity. With a gender of female and the ability to support Ethernet 40GBase-X, this expansion module is designed to enhance your network's performance. -
High-speed performance
Boasting a data transfer rate of 40 Gbps, the NETGEAR APM402XL ensures that your data flows quickly and efficiently. This performance is ideal for tasks that demand substantial bandwidth, making it a suitable choice for enterprise environments. -
Seamless integration
Designed as a Plug-and-Play module, the NETGEAR APM402XL offers seamless integration with existing network infrastructure. Its form factor allows for easy installation, ensuring that your network is up and running without significant downtime.
 - NETGEAR APM402XL - expansion module - 40 Gigabit QSFP+ x 2
 - Expansion module
- Form Factor
 - Plug-in module
- Ports
 - 300 g
- Localisation
 - Worldwide
- Cabling Type
 - Ethernet 40GBase-X
- Data Link Protocol
 - 40GbE
- Data Transfer Rate
 - 40 Gbps
 - Expansion module
- Form Factor
 - Plug-in module
- Localisation
 - Worldwide
- Ports
- Connectivity Technology
 - Wired
- Cabling Type
 - 40 Gigabit Ethernet
 - 40 Gbps
 - 2 x 40GBase-X - QSFP+ - female
 - 300 g
