NETGEAR 2 x 40GBASE-X QSFP+ Port Card For M4300-96X
Quicklinx: DF3QWS00 Mfr#: APM402XL-10000S
Wired / Wireless: Wired
Protocol: 40 Gigabit Ethernet
Form Factor: Plug-in module
Compatibility: [N/A]
Type: Expansion module
£510.35 ex VAT
£612.42 inc VAT
Compatible with M4300-96X models (XSM4396K0, XSM4396K1). The NETGEAR M4300-96X is a 2RU modular switch that comes either empty or pre-populated with 48 SFP+ ports and supporting up to 96-port 10GBASE-T copper (RJ-45) with first 48 ports capable of PoE+, 96-port 10GBASE-X fiber (SFP+), 24-port 40GBASE-X fiber (QSFP+), or a combination. The M4300 family provides world-class services for server and storage interconnect, mid-enterprise edge and SMB core. SDVoE-Ready, M4300 switches streamline AV-over-IP deployments with Zero Touch multicast. Layer 3 feature set includes static, policy-based and dynamic routing as standard.
  • Enhanced connectivity
    The NETGEAR APM402XL features two QSFP+ connectors, providing robust and reliable connectivity. With a gender of female and the ability to support Ethernet 40GBase-X, this expansion module is designed to enhance your network's performance.
  • High-speed performance
    Boasting a data transfer rate of 40 Gbps, the NETGEAR APM402XL ensures that your data flows quickly and efficiently. This performance is ideal for tasks that demand substantial bandwidth, making it a suitable choice for enterprise environments.
  • Seamless integration
    Designed as a Plug-and-Play module, the NETGEAR APM402XL offers seamless integration with existing network infrastructure. Its form factor allows for easy installation, ensuring that your network is up and running without significant downtime.
NETGEAR APM402XL - expansion module - 40 Gigabit QSFP+ x 2
Expansion module
Plug-in module
Ports
300 g
Worldwide
Cabling Type
Ethernet 40GBase-X
40GbE
Data Transfer Rate
40 Gbps
Expansion module
Plug-in module
Worldwide
Ports
Wired
Cabling Type
Ethernet 40GBase-X
40 Gigabit Ethernet
Data Transfer Rate
40 Gbps
2 x 40GBase-X - QSFP+ - female
300 g
Brand: NETGEAR
Price Range Ex VAT: £500 - £750
