NETGEAR 1G-28P-POE+SFP+ Cloud Switch
Quicklinx: D9Q0WS00 Mfr#: GC728XP-100EUS
The Insight Managed Smart Cloud Gigabit Ethernet/10G SFP+ Switches are the first switches from NETGEAR with anywhere configuration and management. Using either the NETGEAR Insight app on your mobile device or tablet, or the Insight Cloud Portal from your PC, Mac, or tablet, you can quickly discover, setup, monitor and manage your Smart Cloud Switches from anywhere in the world! With their remote cloud manageability, sleek design, and combination of Gigabit copper, Gigabit SFP fiber, and 10G SFP+ fiber ports, Insight Managed Smart Cloud Switches are the most versatile switches in the market for any environment. Whether at home, out of the office or on a business trip, you can still manage and monitor your network as if you were right there.
  • Robust security
    Equipped with Extensible Authentication Protocol (EAP), RADIUS, TACACS+, and advanced encryption algorithms including MD5, PEAP, SSL 3.0, and TLS 1.0, this switch ensures secure network access and data transmission.
  • High-capacity networking
    With support for up to 256 VLANs, 100 ACLs, and 512 IGMP multicast groups, alongside static routing for both IPv4 and IPv6, the NETGEAR Smart GC728XP is designed to handle extensive networking demands.
  • Efficient power management
    Featuring a generous PoE budget of 390 W and ENERGY STAR compliance, this switch optimizes power usage across all connected devices, reducing operational costs.
  • High performance
    Boasting a fabric throughput of 92 Gbps and forwarding performance of 68.5 Mpps, coupled with a 1.5MB packet buffer and a 16K MAC address table, the switch delivers high-speed data processing and transmission.
  • Flexible connectivity
    Offers a variety of ports including 24 RJ-45 connectors for 10/100/1000 Base-T (PoE+), 2 Gigabit SFP uplinks, and 2 10 Gigabit SFP+ uplinks, ensuring versatile connectivity options for a wide range of network architectures.
NETGEAR Smart GC728XP - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - L3 - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 2 x Gigabit SFP (uplink) + 2 x 10 Gigabit SFP+ (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
390 W
Performance
Fabric throughput: 92 Gbps , Forwarding performance (64-byte packet size): 68.5 Mpps
ACL: 100 , VLANs supported: 256 , Priority queues: 8 , IGMP multicast groups: 512 , IPv4 routes (static): 32 , IPv6 routes (static): 31
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
ARP support, IGMP snooping, Syslog support, SPI, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, LACP support, LLDP support, DHCP relay, DHCP client, Energy Efficient Ethernet, MVR, dual firmware images, SPQ, NDP, loop prevention, security lock slot (cable lock sold separately), ToS, DSCP support, 2 fans, 1.5MB packet buffer, cable test, administrator's password, ICMP IRDP, DNS client, guest access, WRR, loopback detection
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
44 cm x 22.4 cm x 4.4 cm
3.79 kg
United Kingdom, Europe
5-year warranty
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
390 W
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
MD5, TLS 1.0, SSL 3.0, PEAP
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
1 Cortex-A9: 400 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Power, status, fan, link/activity/speed
24 x 10/100/1000 Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP , 2 x 10GBase-X SFP+ , USB
Internal power supply
437.1 watt
Rubber feet
Rack Mounting Kit
Included
MTBF
629,962 hours
CCC, UL 60950-1 Second Edition, KCC, K60950-1, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class A, GB 4943.1-2011, EN 55024:2010+A1:2015, KN32, KN35, BSMI CNS13438:2006 Class A, EN 55032:2012+AC:2013 Class A, CNS 14336-1, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, EN 61000-3-2:2014 Class A, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2015 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
44 cm
22.4 cm
4.4 cm
3.79 kg
Limited warranty - replacement - 5 years - response time: next business day , Limited warranty - power supply - 2 years , Technical support - 90 days
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
