As a leading provider of network equipment for SMBs, NETGEAR understands the importance of reliable and high performance networks. With the growth of virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, SMB networks need to extend beyond simple reliability to simpler management and remote monitoring to ensure your network is "always up" .NETGEAR also understands that small business owners shouldn't have to understand networking and IT; they need a network that's easy-to-setup and is reliable, so they can focus on their business, not their network.
The Insight Managed Smart Cloud Gigabit Ethernet/10G SFP+ Switches are the first switches from NETGEAR with anywhere configuration and management. Using either the NETGEAR Insight app on your mobile device or tablet, or the Insight Cloud Portal from your PC, Mac, or tablet, you can quickly discover, setup, monitor and manage your Smart Cloud Switches from anywhere in the world! With their remote cloud manageability, sleek design, and combination of Gigabit copper, Gigabit SFP fiber, and 10G SFP+ fiber ports, Insight Managed Smart Cloud Switches are the most versatile switches in the market for any environment. Whether at home, out of the office or on a business trip, you can still manage and monitor your network as if you were right there.
Remote monitoring and management from the palm of your hand
With the NETGEAR Insight mobile app, you can setup, manage, and monitor your networks from anywhere, anytime, from the palm of your hand on your phone or tablet! Or, for a larger screen experience, you can use the Insight Cloud Portal from your PC, Mac, or tablet web browser. -
Network-centric configuration and management
NETGEAR Insight Managed Switches and Wireless Access Points using the NETGEAR Insight app or Insight Cloud Portal allow for cross-device automated configuration of VLANs, QoS, ACLs, and LAGs. Auto-join and configure (zero-touch privisioning) allows for additional devices added and provisioned seamlessly. -
Fully-integrated cloud-manageable devices
NETGEAR Insight Managed switches are fullyintegrated, cloud-manageable, Plug-and-Play devices. Just connect to your network and without any setup, they're passing traffic. For configuration setup, management, and monitoring, you can use the Insight mobile app on your mobile device or the Insight Cloud Portal from your PC, Mac, or tablet web browser. No additional cloud controller, appliance, network manager, or on-premise cloud server necessary. -
Clean, sleek designs
Insight Managed switches have a modern, clean design, with at-a-glance cloud, power, fan, and PoE max LEDs for quick status monitoring. On-port LEDs for link/activity and PoE power allow for port-specific connectivity monitoring.
- NETGEAR Smart GC728X - switch - 24 ports - smart - rack-mountable
- Switch - 24 ports - L3 - smart
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 2 x Gigabit SFP (uplink) + 2 x 10 Gigabit SFP+ (uplink)
- Performance
- Fabric throughput: 92 Gbps , Forwarding performance (64-byte packet size): 68.5 Mpps
- Capacity
- ACL: 100 , VLANs supported: 256 , Priority queues: 8 , IGMP multicast groups: 512 , IPv4 routes (static): 32 , IPv6 routes (static): 31
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
- ARP support, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), LACP support, LLDP support, DHCP relay, DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), Neighbor Discovery Protocol (NDP), loop prevention, security lock slot (cable lock sold separately), Type of Service (ToS), DiffServ Code Point (DSCP) support, 1.5MB packet buffer, cable test, administrator's password, ICMP Router Discovery Protocol (IRDP), DNS client, 1 fan, guest access, Weighted Round Robin (WRR), loopback detection
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 120/230 V (50 - 60 Hz)
- 44 cm x 22.4 cm x 4.4 cm
- 2.81 kg
- Localisation
- United Kingdom, Europe
- 5-year warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- MD5, TLS 1.0, SSL 3.0, PEAP
- Authentication Method
- RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
- Processor
- 1 Cortex-A9: 400 MHz
- RAM
- 512 MB
- Flash Memory
- 256 MB
- Status Indicators
- Power, status, fan, link/activity/speed
- 24 x 10/100/1000 Base-T RJ-45 , 2 x 1000Base-X SFP , 2 x 10GBase-X SFP+ , USB
- Power Device
- Internal power supply
- Voltage Required
- 18.5 Watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- MTBF
- 1,874,356 hours
- CCC, UL 60950-1 Second Edition, KCC, K60950-1, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class A, GB 4943.1-2011, EN 55024:2010+A1:2015, KN32, KN35, BSMI CNS13438:2006 Class A, EN 55032:2012+AC:2013 Class A, CNS 14336-1, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, EN 61000-3-2:2014 Class A, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2015 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- 44 cm
- 22.4 cm
- 4.4 cm
- 2.81 kg
- Limited warranty - replacement - 5 years - response time: next business day , Limited warranty - power supply - 2 years , Technical support - 90 days
- 0 °C
- 50 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
