NetGear 16Port Gigabit Smart Switch
Quicklinx: 98F6WS00 Mfr#: GS716T-300EUS
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£100.79 ex VAT
£120.94 inc VAT
The NETGEAR ProSAFE Gigabit Smart Managed switches offer powerful Layer 3 Lite features with enhanced performance and usability. They are purposely designed for the future where increased traffic and application-oriented tasks demands more intelligence at the edge, higher reliability and improved network efficiency on top of operational cost savings and ease of management.
  • Comprehensive QoS features
    Port-based or 802.1p-based prioritization. Layer 3-based (DSCP) prioritization. Port-based ingress and egress rate limiting. Advanced controls for optimized network performance and better delivery of mission-critical traffic such as voice and video.
  • DHCP Snooping
    Ensure IP address allocation integrity by allowing only clients with specific IP/MAC addresses to have access to the network.
  • Dual firmware images and configuration files
    Dual firmware image and dual configuration file for transparent firmware updates/configuration changes with minimum service interruption.
  • Protected ports
    Ensure no exchange of unicast, broadcast, or multicast traffic between the protected ports on the switch, therefore, improve the security of your converged network where your sensitive phone conversation can stay private and your surveillance video clips can be forwarded to their designated storage device without leakage or alteration.
  • Dynamic ARP inspection
    Prevents a class of man-in-the-middle attacks, where an unfriendly station intercepts traffic for other stations by poisoning the ARP caches of its unsuspecting neighbors.
  • Multicast VLAN registration
    Eliminates the replication of the same multicast traffic for every VLAN by sending multicast traffic only on to the dedicated multicast/source VLAN, resulting in more efficient utilization of network bandwidth.
NETGEAR Smart GS716T - v3 - switch - 16 ports - Managed - rack-mountable
Switch - 16 ports - L3 Lite - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 + 2 x Gigabit SFP
Performance
Bandwidth: 36 Gbps
Virtual interfaces (VLANs): 256 , ACL entries: 100 , Static routes: 32 , Layer 2 multicast groups: 512 , ARP entries: 512 , Priority queues per port: 8
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP
Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, MLD snooping, DAI, LLDP support, DHCP client, Energy Efficient Ethernet, SPQ, static routing, 802.1x authentication, ToS, VoIP support, DSCP support, cable test, administrator's password, ARP inspection
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
44 cm x 20.4 cm x 4.3 cm
2.57 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Bandwidth: 36 Gbps
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL, TLS 1.0
Authentication Method
RADIUS, TACACS+
Status Indicators
Port transmission speed, link/activity
16 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP uplink
Internal power supply
14.4 Watt
Rack Mounting Kit
Included
MTBF
726,612 hours
cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, CISPR 22, EN50082-1, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A, TLS v1.0
Europe
Software Included
Drivers & Utilities
44 cm
20.4 cm
4.3 cm
2.57 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
98F6 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
98F6 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.92
98F6 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.60
Ports: 16
Managed: Yes
POE: No
Brand: NETGEAR
