NETGEAR 16-port POE+ Gigabit Unmanaged Switch
Quicklinx: DWF1WS00 Mfr#: GS116PP-100EUS
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: [N/A]
Managed: No
POE: PoE+
Hurry, only 1 left in stock!
£152.48 ex VAT
£182.97 inc VAT
Desktop, Wall-mount and 19-inch Rackmountable
Small Form Factor
Silent Design
Small form factor and silent for quiet operation makes it the ideal switch for noise-sensitive environments.
The NETGEAR GS116PP ProSAFE FlexPoE Gigabit Unmanaged Switch helps businesses cost-effectively increase power budget to expand their network. Powered by the industry's first flexible PoE+ integrated technology, you can increase or decrease the PoE budget by simply buying a new power supply, effectively future-proofing small business networks and budgets.
  • Robust performance
    With a bandwidth of 32 Gbps, the NETGEAR GS116PP switch ensures efficient handling of network traffic, maintaining optimal performance even in high-demand scenarios.
  • Comprehensive connectivity
    Equipped with 16 RJ-45 connectors supporting PoE+, this switch offers extensive connectivity options for a wide range of devices, facilitating easy network expansion.
  • Versatile installation
    The NETGEAR GS116PP is designed for flexibility, supporting desktop, rack-mountable, and wall-mountable setups to fit various spatial requirements and deployment scenarios.
  • Efficient power management
    With a total PoE budget of 183 W and an external power adapter providing 200 W, this switch efficiently distributes power to connected devices, reducing the need for additional power sources.
  • Advanced networking features
    Features such as Class of Service (CoS), DiffServ Code Point (DSCP) support, and Jumbo Frames support enhance the network's ability to manage data efficiently, ensuring smooth and reliable data transmission.
NETGEAR GS116PP - switch - 16 ports - unmanaged - rack-mountable
Switch - 16 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
183 W
Performance
Bandwidth: 32 Gbps
MAC Address Table Size
4K entries
Flow control, full duplex capability, store and forward, WFQ, QoS, Jumbo Frames support, fanless, Energy Efficient Ethernet, 1MB packet buffer, CoS, DSCP support, EEE, WRR
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
DC 54 V
28.6 cm x 10.2 cm x 2.7 cm
880 g
United Kingdom, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
183 W
Performance
Bandwidth: 32 Gbps
4K entries
Status Indicators
Power, PoE, link/activity/speed
16 x 1000Base-T RJ-45 PoE+
External power adapter
Power Provided
200 Watt
DC 54 V
Wall mounting kit
Rack Mounting Kit
Included
MTBF
2,088,514 hours
UL, cUL, UL 60950-1 Second Edition, CNS 13438, EN 61000-3-3:2013, EN 55024:2010, FCC CFR47 Part 15 B Class A, KN32, KN35, EN 55032:2012+AC:2013 Class A, CNS 14336-1, ANSI C63.4-2014, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, EN 61000-3-2:2014 Class A, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2015 Class A, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
28.6 cm
10.2 cm
2.7 cm
880 g
Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 16
Managed: No
POE: PoE+
Brand: NETGEAR
