NETGEAR 16 Port Gigabit Compact Switch
Customer rating: 5.0* (Write a review)
Quicklinx: 3F1VWS00 Mfr#: GS116UK
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: 1Gbps
Managed: No
POE: No
£69.88 ex VAT
£83.85 inc VAT
Now you can have a powerful, high-speed network on a small scale. NETGEAR's GS116 Gigabit Ethernet Switch lets you build a system that provides a full, dedicated 1000 Mbps connections so you can move very large files across your network instantly. The standards-based GS116 helps to protect your existing and future network infrastructure investments by painlessly integrating other 10,100, and 1000 Mbps devices. This potent switch is ideal for workgroups or quickly upgrading workstations to full Gigabit speed, plus it's packed with ease-of-use features to simplify your workday experience. Its compact design fits neatly into small work spaces and, since it's self-cooling without a fan, it runs silently and unobtrusively.
  • Power up your small network to gigabit speeds
    Now you can have a powerful, high-speed network on a small scale. NETGEAR's ProSafe GS116 Gigabit Ethernet Switch lets you build a system that provides full, dedicated 1000 Mbps connections so you can move very large files across your network instantly. The standards-based GS116 helps to protect your existing and future network infrastructure investments by painlessly integrating other 10, 100, and 1,000 Mbps devices.
  • Power-packed
    Moves huge files fast! Features 16 high-speed, auto-switching 10/100/1000 Mbps Ethernet connections. And because copper Gigabit Ethernet is a full duplex standard, you can get up to 2000 Mbps on each port. The GS116 supports jumbo frames up to 9,000 Bytes for extra large transfers.
  • Versatile
    Integrates 10, 100, and 1000 Mbps devices on the same network and will honor Layer 2 802.1p and Layer 3 DSCP traffic priority tags. Every port automatically senses the right speed and full/ half duplex mode, while Auto Uplink technology automatically adjusts for straight-through or crossover cables.
  • Accommodating
    LEDs embedded in each of the 16 RJ-45 jacks make for easy monitoring. Space-saving dimensions are ideal for desktop or wall-mounting in home, small office, workgroups, departments and conference room environments. Its durable metal case has no fan for silent operation.
  • Solid
    Providing plug-and-play simplicity with exceptional performance and reliability, the GS116 is a cost-effective solution for your growing network.
NETGEAR GS116 16 Port Gigabit Desktop Switch - switch - 16 ports
Switch - 16 ports
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
MAC Address Table Size
8K entries
Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p
28.5 cm x 10.3 cm x 2.7 cm
0.9 kg
NETGEAR lifetime warranty
Switch - 16 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
8K entries
Status Indicators
Port status, port transmission speed, power, link/activity
16 x 1000Base-T RJ-45
External power adapter
25 Watt
Mounting Kit
Included
FCC Class A certified, C-Tick, EN55022, UL 1950, VCCI Class A ITE, CISPR 22
28.5 cm
10.3 cm
2.7 cm
0.9 kg
10 - 90%
3F1V C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
Customer reviews
Write a review for the NETGEAR 16 Port Gigabit Compact Switch here!
Great deal
Reviewed by Gwyn Pritchard. Review Posted 16/05/2008
Easy to use, no setup needed.
highly recommended. Ordered 5pm arrived 9.30am the next day
Great service
well done
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Good Value
Reviewed by Richard Bibby. Review Posted 06/09/2006
Easy set up with no need to read manual. Auto detects 10/100/1000 speeds so you can mix old and new devices with no problems. Seems fast on my win98se network but there isn't a dramatic increase in speed in day to day use. Better when moving large data files. Box gets quite warm and has external power supply. Unit is compact and light but can be screwed down.
Cheap for a 16 port switch.
  • Overall 5*
  • Ease of use 5*
GREAT
Reviewed by BLAKE. Review Posted 12/12/2006
EASY TO SETUP, CONFIGURE AND EXCELLENT ROBUST DESIGN!
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Ports: 16
Managed: No
POE: No
Brand: NETGEAR
