Now you can have a powerful, high-speed network on a small scale. NETGEAR's GS116 Gigabit Ethernet Switch lets you build a system that provides a full, dedicated 1000 Mbps connections so you can move very large files across your network instantly. The standards-based GS116 helps to protect your existing and future network infrastructure investments by painlessly integrating other 10,100, and 1000 Mbps devices. This potent switch is ideal for workgroups or quickly upgrading workstations to full Gigabit speed, plus it's packed with ease-of-use features to simplify your workday experience. Its compact design fits neatly into small work spaces and, since it's self-cooling without a fan, it runs silently and unobtrusively.
Power up your small network to gigabit speeds
Now you can have a powerful, high-speed network on a small scale. NETGEAR's ProSafe GS116 Gigabit Ethernet Switch lets you build a system that provides full, dedicated 1000 Mbps connections so you can move very large files across your network instantly. The standards-based GS116 helps to protect your existing and future network infrastructure investments by painlessly integrating other 10, 100, and 1,000 Mbps devices. -
Power-packed
Moves huge files fast! Features 16 high-speed, auto-switching 10/100/1000 Mbps Ethernet connections. And because copper Gigabit Ethernet is a full duplex standard, you can get up to 2000 Mbps on each port. The GS116 supports jumbo frames up to 9,000 Bytes for extra large transfers. -
Versatile
Integrates 10, 100, and 1000 Mbps devices on the same network and will honor Layer 2 802.1p and Layer 3 DSCP traffic priority tags. Every port automatically senses the right speed and full/ half duplex mode, while Auto Uplink technology automatically adjusts for straight-through or crossover cables. -
Accommodating
LEDs embedded in each of the 16 RJ-45 jacks make for easy monitoring. Space-saving dimensions are ideal for desktop or wall-mounting in home, small office, workgroups, departments and conference room environments. Its durable metal case has no fan for silent operation. -
Solid
Providing plug-and-play simplicity with exceptional performance and reliability, the GS116 is a cost-effective solution for your growing network.
- NETGEAR GS116 16 Port Gigabit Desktop Switch - switch - 16 ports
- Switch - 16 ports
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000
- MAC Address Table Size
- 8K entries
- Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p
- 28.5 cm x 10.3 cm x 2.7 cm
- 0.9 kg
- NETGEAR lifetime warranty
- Switch - 16 ports
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000
- 8K entries
- Status Indicators
- Port status, port transmission speed, power, link/activity
- 16 x 1000Base-T RJ-45
- Power Device
- External power adapter
- 25 Watt
- Mounting Kit
- Included
- FCC Class A certified, C-Tick, EN55022, UL 1950, VCCI Class A ITE, CISPR 22
- 28.5 cm
- 10.3 cm
- 2.7 cm
- 0.9 kg
- 0 °C
- 40 °C
- 10 - 90%
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £4.30 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.64 |
Customer reviews
Write a review for the NETGEAR 16 Port Gigabit Compact Switch here!
Great deal
Reviewed by Gwyn Pritchard. Review Posted 16/05/2008
Easy to use, no setup needed.
highly recommended. Ordered 5pm arrived 9.30am the next day
Great service
well done
Overall
Ease of use
Value for money
Good Value
Reviewed by Richard Bibby. Review Posted 06/09/2006
Easy set up with no need to read manual. Auto detects 10/100/1000 speeds so you can mix old and new devices with no problems. Seems fast on my win98se network but there isn't a dramatic increase in speed in day to day use. Better when moving large data files. Box gets quite warm and has external power supply. Unit is compact and light but can be screwed down.
Cheap for a 16 port switch.
Overall
Ease of use
Value for money
GREAT
Reviewed by BLAKE. Review Posted 12/12/2006
EASY TO SETUP, CONFIGURE AND EXCELLENT ROBUST DESIGN!
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
