NETGEAR ProSAFE Modular Power Supply Unit 150W AC (APS150W) is compatible with select Managed Switches such as M4300-28G (GSM4328S) and M4300-52G (GSM4352S). These M4300 series switches come with one PSU pre-installed. These M4300 series switches come with one PSU pre-installed. Another APS150W in second PSU bay can be combined for 1+1 power redundancy or 1+1 power expansion.
Efficient power supply
Designed to deliver a robust 150 W of power, the NETGEAR APS150W is ideal for supporting the energy needs of network hardware. Its compatibility with a wide range of network devices ensures a reliable power source for critical infrastructure. -
Versatile connectivity
Featuring a power IEC 60320 C14 input connector, this power supply unit offers versatile connectivity options. This standard compatibility ensures it can easily integrate with existing network setups without the need for additional adapters.
- NETGEAR APS150W - power supply - redundant - 150 Watt
- Power supply - redundant - internal
- Localisation
- Europe, Americas
- Input Voltage
- AC 110-240 V
- Power Capacity
- 150 Watt
- Input Connectors
- Power IEC 60320 C14
- 5-year warranty
- Designed For
- NETGEAR M4300-28G, M4300-52G
- Localisation
- Europe, Americas
- Input Voltage
- AC 110-240 V
- Input Connectors
- Power Capacity
- 150 Watt
- Limited warranty - 5 years
- Designed For
