NETGEAR 150W 100-240VAC Power Supply Unit
Quicklinx: CDW3WS00 Mfr#: APS150W-100NES
£147.92 ex VAT
£177.50 inc VAT
NETGEAR ProSAFE Modular Power Supply Unit 150W AC (APS150W) is compatible with select Managed Switches such as M4300-28G (GSM4328S) and M4300-52G (GSM4352S). These M4300 series switches come with one PSU pre-installed. These M4300 series switches come with one PSU pre-installed. Another APS150W in second PSU bay can be combined for 1+1 power redundancy or 1+1 power expansion.
  • Efficient power supply
    Designed to deliver a robust 150 W of power, the NETGEAR APS150W is ideal for supporting the energy needs of network hardware. Its compatibility with a wide range of network devices ensures a reliable power source for critical infrastructure.
  • Versatile connectivity
    Featuring a power IEC 60320 C14 input connector, this power supply unit offers versatile connectivity options. This standard compatibility ensures it can easily integrate with existing network setups without the need for additional adapters.
NETGEAR APS150W - power supply - redundant - 150 Watt
Power supply - redundant - internal
Europe, Americas
Input Voltage
AC 110-240 V
Power Capacity
150 Watt
Input Connectors
Power IEC 60320 C14
5-year warranty
NETGEAR M4300-28G, M4300-52G
Europe, Americas
Input Voltage
AC 110-240 V
Input Connectors
Power IEC 60320 C14
Power Capacity
150 Watt
Limited warranty - 5 years
Type: Power Supply
Brand: NETGEAR
