NETGEAR 130W External Power Supply Unit
Quicklinx: F63KWS00 Mfr#: EPS130W-100UKS
£38.36 ex VAT
£46.03 inc VAT
Future-proof your PoE budget. Increase or decrease your PoE budget anytime by simply upgrading your switch power supply, without having to purchase a new switch. Select NETGEAR Gigabit Ethernet Unmanaged Switches include a built-in PoE power selector lever, which lets you connect a compatible power adapter to increase or decrease the PoE power available on the switch.
NETGEAR 130W External Power Supply Unit (EPS130W) - power adapter - 130 Watt
Power adapter - external
United Kingdom
Output Voltage
54 V
Power Capacity
130 Watt
United Kingdom
Output Voltage
54 V
Max Electric Current
2.4 A
Power Capacity
130 Watt
Power cable - detachable
Limited warranty - 2 years , Technical support - 90 days
Brand: NETGEAR
