Future-proof your PoE budget. Increase or decrease your PoE budget anytime by simply upgrading your switch power supply, without having to purchase a new switch. Select NETGEAR Gigabit Ethernet Unmanaged Switches include a built-in PoE power selector lever, which lets you connect a compatible power adapter to increase or decrease the PoE power available on the switch.
- NETGEAR 130W External Power Supply Unit (EPS130W) - power adapter - 130 Watt
- Power adapter - external
- Localisation
- United Kingdom
- Output Voltage
- 54 V
- Power Capacity
- 130 Watt
- 2-year warranty
- Localisation
- United Kingdom
- Output Voltage
- 54 V
- Max Electric Current
- 2.4 A
- Power Capacity
- 130 Watt
- Cables Included
- Power cable - detachable
- Limited warranty - 2 years ¦ Technical support - 90 days
