Through an intuitive GUI, it provides easy, reliable and affordable connectivity with VLAN, QoS, LAG and IGMP management capabilities. The flexible mounting options (rackmount or desktop) and the silent design make the XS512EM ideal for any SMB environment. The XS512EM also includes the full set of Smart Managed Plus software features, such as traffic prioritization and link aggregation.
Robust performance
With a fabric throughput of 240 Gbps and forwarding performance capable of handling 178.6 million packets per second, this switch is engineered to manage high-volume traffic efficiently, ensuring smooth network operations even under heavy loads. -
Versatile connectivity
Equipped with 12 ports supporting speeds up to 10GBase-T and two combo 10 Gigabit SFP+ ports, the NETGEAR Plus XS512EM offers flexible connection options for a variety of devices, making it a suitable solution for diverse networking environments. -
Advanced network management
Manageable via HTTP and TFTP, this switch provides comprehensive control over your network. Features like VLAN support, Quality of Service (QoS), and Link Aggregation Control Protocol (LACP) allow for efficient traffic prioritization and enhanced security. -
Energy efficient
Incorporating Energy Efficient Ethernet and featuring two fans for optimal cooling, the NETGEAR Plus XS512EM is designed to minimize power consumption while maintaining operational efficiency, contributing to a lower total cost of ownership. -
Durable and reliable
With a mean time between failures (MTBF) of over 1 million hours and a robust set of compliance standards, this switch is built to deliver reliable performance and withstand the rigors of intensive daily use in demanding environments.
- NETGEAR Plus XS512EM - switch - 12 ports - smart - rack-mountable
- Switch - 12 ports - smart
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 10 x 100/1000/2.5G/5G/10GBase-T + 2 x combo 10 Gigabit SFP+
- Performance
- Fabric throughput: 240 Gbps , Forwarding performance (64-byte packet size): 178.6 Mpps
- Capacity
- Priority queues: 8 , IGMP multicast groups: 128
- MAC Address Table Size
- 32K entries
- Jumbo Frame Support
- 9000 bytes
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- HTTP, TFTP
- VLAN support, IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, QoS, LACP, DHCP client, Energy Efficient Ethernet, loop prevention, Multicast filtering function, CoS, ToS, DSCP support, 2 fans, 3MB packet buffer, cable test, administrator's password, WRR, VLAN Tagging, port trunking
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz
- Power
- AC 120/230 V (50 - 60 Hz)
- 32.8 cm x 20.4 cm x 4.3 cm
- 2.51 kg
- Localisation
- Europe
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 32K entries
- 9000 bytes
- Routing Protocol
- HTTP, TFTP
- Status Indicators
- Power, link/activity/speed
- 12 x 100/1000/2.5G/5G/10GBase-T RJ-45 , 2 x 10GBase-X SFP+
- Power Device
- Internal power supply
- Voltage Required
- 76.56 Watt
- Rack Mounting Kit
- Included
- MTBF
- 1,113,477 hours
- UL 60950-1, KC, CNS 13438, EN 55024:2010, FCC CFR47 Part 15 B Class A, EN 55032:2012+AC:2013 Class A, CNS 14336-1, ANSI C63.4-2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, EN 61000-3-2:2014 Class A, CAN/CSA-C22.2 No. 60960-1-07, AS/NZS CISPR32:2013 Class A, EN 6100-3-3:2013, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, VCCI-CISPR 32:2016, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- Europe
- 32.8 cm
- 20.4 cm
- 4.3 cm
- 2.51 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
