NETGEAR 12-Port 10-Gigabit/Multi-Gigabit Ethernet
Quicklinx: D7YJWS00 Mfr#: XS512EM-100EUS
Type: 10 Gigabit Ethernet
Ports: 12
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
£945.43 ex VAT
£1,134.51 inc VAT
Through an intuitive GUI, it provides easy, reliable and affordable connectivity with VLAN, QoS, LAG and IGMP management capabilities. The flexible mounting options (rackmount or desktop) and the silent design make the XS512EM ideal for any SMB environment. The XS512EM also includes the full set of Smart Managed Plus software features, such as traffic prioritization and link aggregation.
  • Robust performance
    With a fabric throughput of 240 Gbps and forwarding performance capable of handling 178.6 million packets per second, this switch is engineered to manage high-volume traffic efficiently, ensuring smooth network operations even under heavy loads.
  • Versatile connectivity
    Equipped with 12 ports supporting speeds up to 10GBase-T and two combo 10 Gigabit SFP+ ports, the NETGEAR Plus XS512EM offers flexible connection options for a variety of devices, making it a suitable solution for diverse networking environments.
  • Advanced network management
    Manageable via HTTP and TFTP, this switch provides comprehensive control over your network. Features like VLAN support, Quality of Service (QoS), and Link Aggregation Control Protocol (LACP) allow for efficient traffic prioritization and enhanced security.
  • Energy efficient
    Incorporating Energy Efficient Ethernet and featuring two fans for optimal cooling, the NETGEAR Plus XS512EM is designed to minimize power consumption while maintaining operational efficiency, contributing to a lower total cost of ownership.
  • Durable and reliable
    With a mean time between failures (MTBF) of over 1 million hours and a robust set of compliance standards, this switch is built to deliver reliable performance and withstand the rigors of intensive daily use in demanding environments.
NETGEAR Plus XS512EM - switch - 12 ports - smart - rack-mountable
Switch - 12 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
10 x 100/1000/2.5G/5G/10GBase-T + 2 x combo 10 Gigabit SFP+
Performance
Fabric throughput: 240 Gbps , Forwarding performance (64-byte packet size): 178.6 Mpps
Priority queues: 8 , IGMP multicast groups: 128
MAC Address Table Size
32K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
HTTP, TFTP
VLAN support, IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, QoS, LACP, DHCP client, Energy Efficient Ethernet, loop prevention, Multicast filtering function, CoS, ToS, DSCP support, 2 fans, 3MB packet buffer, cable test, administrator's password, WRR, VLAN Tagging, port trunking
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz
AC 120/230 V (50 - 60 Hz)
32.8 cm x 20.4 cm x 4.3 cm
2.51 kg
Europe
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
HTTP, TFTP
Status Indicators
Power, link/activity/speed
12 x 100/1000/2.5G/5G/10GBase-T RJ-45 , 2 x 10GBase-X SFP+
Internal power supply
76.56 Watt
Rack Mounting Kit
Included
MTBF
1,113,477 hours
UL 60950-1, KC, CNS 13438, EN 55024:2010, FCC CFR47 Part 15 B Class A, EN 55032:2012+AC:2013 Class A, CNS 14336-1, ANSI C63.4-2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, EN 61000-3-2:2014 Class A, CAN/CSA-C22.2 No. 60960-1-07, AS/NZS CISPR32:2013 Class A, EN 6100-3-3:2013, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, VCCI-CISPR 32:2016, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe
32.8 cm
20.4 cm
4.3 cm
2.51 kg
Limited warranty - lifetime
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 12
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: £750 - £1000
