NETGEAR 10P GE POE+ Smart Switch 75W
Quicklinx: CZPNWS00 Mfr#: GS510TLP-100EUS
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
POE: PoE+
£147.66 ex VAT
£177.19 inc VAT
As a leading provider of network equipment for SMBs, NETGEAR understands the importance of providing great choice of PoE port counts and power budgets that can adapt to the business's needs, whether in the hospitality, catering, education or retail domains. Temperature- and load-based fan-speed control combines accurate monitoring with minimized system acoustic noise: unlike other high power PoE switches on the market, the GS510TPP supports quiet desktop operation or rack mounting with a maximum of 32 dB at full power and 25°C (77°F) ambient.
  • Efficient power management
    With a generous PoE budget of 75 W, the NETGEAR Smart GS510TLP switch supports multiple powered devices efficiently, making it ideal for various network setups.
  • Advanced security features
    Equipped with Access Control List (ACL) support, 802.1x authentication, and DoS attack prevention, this switch ensures a secure network environment, protecting against unauthorized access and various types of cyber threats.
  • High-speed connectivity
    Featuring 8 RJ-45 connectors for 1000Base-T and 2 SFP ports for 1000Base-X, the switch offers high-speed connections and enhanced flexibility for network configuration.
  • Smart network management
    This manageable switch comes with Layer 3 Lite advanced switching, Quality of Service (QoS), and VLAN support, providing a smart solution for traffic prioritization and network segmentation.
  • Energy-efficient design
    The fanless design not only ensures silent operation but also contributes to energy savings, supported by the ENERGY STAR compliance.
NETGEAR Smart GS510TLP - switch - 8 ports - smart - rack-mountable
Switch - 8 ports - L3 Lite - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
75 W
Performance
Fabric throughput: 20 Gbps , Packet forwarding rate: 14.88 Mpps
Virtual interfaces (VLANs): 256 , ACL: 100 , IPv4 routes (static): 32 , IPv6 routes (static): 32 , IGMP snooping groups: 512 , Priority queues: 8 , Layer 3 multicast groups: 512
MAC Address Table Size
16000 entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, ACL support, QoS, MLD snooping, fanless, LLDP support, DHCP relay, LACP, DHCP client, Energy Efficient Ethernet, MVR, dual firmware images, NAC, 802.1x authentication, DSCP support, 1.5MB packet buffer, ICMP IRDP, IGMP querier
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
32.8 cm x 16.9 cm x 4.3 cm
1.74 kg
Europe
NETGEAR lifetime warranty
NETGEAR WAC740 4 x 4
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
75 W
Performance
16000 entries
Jumbo Frame Support
9KB
Routing Protocol
Cortex-A9: 400 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Port transmission speed, power, link/activity
8 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP
Internal power supply
101 watt
4 foot pads
Rack Mounting Kit
Included
MTBF
913,368 hours
CISPR 22 Class A, EN 60950, UL 1950, EN55024, CSA 22.2 No. 950, AS/NZS 60950-1, CCC, FCC Part 15 A, C-Tick Class A, SCC, VCCI Class A, AS/NZS CISPR22:2009+A1:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55022 Class A, FCC CFR47 Part 15 B Class A, ICES-003 issue 6 Class A, IEC 950, ANSI C63.4-2014, cUL 950, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe
32.8 cm
16.9 cm
4.3 cm
1.74 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Ports: 8
Managed: Yes
POE: PoE+
Brand: NETGEAR
