NETGEAR 10P GE POE+ Smart Switch 190W
Quicklinx: CZPPWS00 Mfr#: GS510TPP-100EUS
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 10Gbps
Managed: Yes
POE: PoE+
22 In Stock
£255.71 ex VAT
£306.85 inc VAT
As a leading provider of network equipment for SMBs, NETGEAR understands the importance of providing great choice of PoE port counts and power budgets that can adapt to the business's needs, whether in the hospitality, catering, education or retail domains. Temperature- and load-based fan-speed control combines accurate monitoring with minimized system acoustic noise: unlike other high power PoE switches on the market, the GS510TPP supports quiet desktop operation or rack mounting with a maximum of 32 dB at full power and 25°C (77°F) ambient.
  • Robust security
    Equipped with Access Control List (ACL) support, 802.1x authentication, and DoS attack prevention, this switch ensures a secure network environment, protecting against unauthorized access and various types of cyber threats.
  • High-capacity networking
    With a fabric throughput of 20 Gbps and a MAC Address Table Size of 16,000 entries, the NETGEAR Smart GS510TPP is designed to handle high volumes of traffic, ensuring smooth data transmission across the network.
  • Efficient power management
    Featuring a generous PoE budget of 190 W and Energy Efficient Ethernet, this switch optimizes power usage across all connected devices, reducing energy costs and supporting a greener operation.
  • Advanced connectivity
    Offers 8 PoE+ ports with 10/100/1000 (PoE+) and 2 SFP (mini-GBIC) ports, providing versatile connection options for a wide range of devices and ensuring high-speed network performance.
  • Easy management and setup
    Manageable via HTTP and HTTPS, this smart switch supports remote management protocols, making setup and management straightforward for network administrators.
NETGEAR Smart GS510TPP - switch - 8 ports - smart - rack-mountable
Switch - 8 ports - L3 Lite - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
190 W
Performance
Fabric throughput: 20 Gbps , Packet forwarding rate: 14.88 Mpps
Virtual interfaces (VLANs): 256 , ACL: 100 , IPv4 routes (static): 32 , IPv6 routes (static): 32 , IGMP snooping groups: 512 , Priority queues: 8 , Layer 3 multicast groups: 512
16000 entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, ACL support, QoS, MLD snooping, LLDP support, DHCP relay, LACP, DHCP client, Energy Efficient Ethernet, MVR, dual firmware images, NAC, 802.1x authentication, DSCP support, 1.5MB packet buffer, ICMP Router Discovery Protocol (IRDP), IGMP querier, 1 fan
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
32.8 cm x 16.9 cm x 4.3 cm
1.83 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
190 W
Performance
16000 entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
RADIUS, TACACS+
Cortex-A9: 400 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Port transmission speed, power, link/activity, fan
8 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP
Internal power supply
225 Watt
4 foot pads
Rack Mounting Kit
Included
MTBF
1,509,979 hours
CISPR 22 Class A, EN 60950, UL 1950, EN55024, CSA 22.2 No. 950, AS/NZS 60950-1, CCC, FCC Part 15 A, C-Tick Class A, SCC, VCCI Class A, AS/NZS CISPR22:2009+A1:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55022 Class A, FCC CFR47 Part 15 B Class A, ICES-003 issue 6 Class A, IEC 950, ANSI C63.4-2014, cUL 950, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe
32.8 cm
16.9 cm
4.3 cm
1.83 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Ports: 8
Managed: Yes
POE: PoE+
Brand: NETGEAR
