This GBIC is built to insert into any one of the two built-in 10 GE SFP+ interfaces of GSM7328Sv2 and GSM7352Sv2, and into the 10 GE SFP+ interface of AX743 adapter module for GSM73xxS/GSM73xxSv2. Once inserted (hot-swappable), the AXM761 10GBASE-SR SFP+ (LC connector) drives 10 Gigabit Ethernet up to 300m distances with 50/125µm OM3 multimode fiber cables, or up to 33 m distances with 62.5/125µm OM1 multimode fiber cables.
Enhanced connectivity
The NETGEAR ProSafe AXM761 model enhances networking with its Ethernet 10GBase-SR interface, providing a high-speed wired connection that supports data transfer rates up to 10 Gigabit Ethernet. This feature ensures rapid data exchanges and enhances network efficiency, making it suitable for businesses requiring fast and reliable connectivity. -
Extended reach
With a maximum transfer distance of 300 m, the NETGEAR ProSafe AXM761 extends the reach of your network. This capability allows for the deployment of networks in larger spaces without sacrificing signal integrity or performance. It's perfect for sprawling office environments, educational institutions, and large retail spaces needing consistent network coverage over vast areas.
- NETGEAR ProSafe AXM761 - SFP+ transceiver module - 10GbE
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 300 m
- Designed For
- NETGEAR M4300-28G-PoE+
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10GbE
- 300 m
- 1 x Ethernet 10GBase-SR
- Compatible Slots
- 1 x SFP+
- Designed For
NETGEAR 10GE SR SFP+ MODULE
