The NETGEAR ProSafe stackable managed 10 Gigabit switch XSM7224S allows for a flexible top-of-rack infrastructure. All 24 ports of 10 Gigabit SFP+ interfaces are 100/1000 capable and deliver wire speed performance with ultra low latency. Local/distant stacking provides versatile 10Gigabit deployment possibilities, such as distributed (LACP) aggregation for virtualized servers and storage.
Enterprise-class L2+
Combining superior resiliency, enterprise-class security, and non-blocking performance, the XSM7224S offers a full set of Layer 2 management features, as well as Layer 2+ (Layer 3 lite - IPv4 routing) with unsurpassed affordability. Together with VLAN routing, voice-class prioritization, and chassis-like stacking, the XSM7224S can be deployed as a data center top-of-rack switch, or closer to the core of small and medium businesses' growing networks, as a distribution layer 10 Gigabit Ethernet aggregation switch. -
Data center availability
The NETGEAR stackable managed 10 Gigabit switch XSM7224S comes with a removable power module for the main power supply with a second internal redundant power supply. Two removable fan trays increase the availability of the system, providing front-to-back cooling airflow.
- NETGEAR XSM7224S - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L2+ - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x SFP+ + 4 x shared 10GBase-T
- Performance
- Switching capacity: 480 Gbps , Throughput: 357 Mpps
- Capacity
- Virtual interfaces (VLANs): 1024 , QoS hardware queues: 8 , ACL rules: 2048 , Static routes: 64 , IP router interfaces: 128
- MAC Address Table Size
- 32000 entries
- Routing Protocol
- OSPF, RIP-1, RIP-2, DVMRP, VRRP, PIM-SM, PIM-DM, OSPFv3, ECMP, RIPng, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, SSH-2
- Layer 2 switching, IGMP snooping, DoS attack prevention, MAC address filtering, firmware upgradable, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, LLDP support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.1AX
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44 cm x 43.1 cm x 4.3 cm
- 6.3 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 32000 entries
- Max Units In A Stack
- 4
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+
- Processor
- 1 x Cavium Networks CN5230: 750 MHz
- RAM
- 512 MB DDR2 SDRAM
- Flash Memory
- 128 MB Flash
- Status Indicators
- Port transmission speed, power, link OK, Unit ID, link/activity, fan
- 4 x 10GBase-T - RJ-45 , 1 x serial (RS-232) DB-9 , 1 x USB Type A , 24 x SFP+
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Voltage Required
- 195.2 Watt
- Included Accessories
- 4 rubber feet
- Cables Included
- 1 x null modem cable
- Rack Mounting Kit
- Included
- MTBF
- 180,178 hours
- CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, FCC Part 15 A, CSA C22.2 No. 950, C-Tick Class A
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 44 cm
- 43.1 cm
- 4.3 cm
- 6.3 kg
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
