NetGear 1000W Power Brick for RPS4000
Quicklinx: BYKZWS00 Mfr#: APS1000W-100NES
Product Type: Power Supply
£559.55 ex VAT
£671.46 inc VAT
The NETGEAR LAN Access and Aggregation Chassis M6100 series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB core deployments, as well as 1G/10G mixed infrastructures in server rooms. Innovative distributed fabric provides non-stop forwarding resiliency and world-class availability - including passive backplane, hitless failover, redundant fabric and redundant management - without having to pay the exorbitant acquisition and maintenance costs associated by other networking vendors in this class. NETGEAR Lan Access and Aggregation Chassis Switch solutions combine the latest advances in hardware and software engineering for higher flexibility, lower complexity and stronger investment protection, at a high-value price point.
NETGEAR APS1000W - power supply - hot-plug / redundant - 1000 watt
Power supply - hot-plug / redundant - plug-in module
1.03 kg
Europe, Americas
Input Voltage
AC 110-240 V
Power Capacity
1000 watt
8.64 cm x 20.75 cm x 3.93 cm
5-year warranty
NETGEAR M4300-52G-PoE+ (1000 watt)
Europe, Americas
Input Voltage
AC 110-240 V
Power Capacity
1000 watt
3 x power cable - external
MTBF
1,272,908 hours
Limited warranty - 5 years
8.64 cm
20.75 cm
3.93 cm
1.03 kg
Brand: NETGEAR
Price Range Ex VAT: £500 - £750
