The NETGEAR 10GBASE-T SFP+ Transceiver (AXM765) delivers 10G copper connectivity with CAT6a or CAT7 cabling up to 30 meters (98.5 feet) when inserted in a switch SFP+ fiber module slot. The AXM765 fits into SFP+ interfaces of M4300, M5300, M6100, M7100 and M7300 Managed Switches, as well as select Smart Managed Pro and Plus Switches. Compatible with the IEEE 802.3an/bz standard, AXM765 delivers Multi-Gigabit copper connectivity with CAT5e or CAT6 cabling up to 100 meters (92.8 feet) when inserted in Multi-Gigabit SFP+ fiber module slot, or Gigabit copper connectivity when inserted in Gigabit SFP fiber module slot.
High-speed connectivity
Experience fast data transfer rates of up to 10 Gbps with the NETGEAR AXM765. This SFP+ transceiver module ensures quick and efficient handling of large data volumes, making it suitable for high-bandwidth applications. -
Extended reach
With a maximum transfer distance of 100 m, the NETGEAR AXM765 offers flexibility in network design and deployment, allowing for efficient connectivity across extended distances within your network infrastructure. -
Robust compatibility
Designed to meet the IEEE 802.3an and IEEE 802.3bz standards, this module is compatible with a wide range of Ethernet 10GBase-T networking equipment, ensuring a smooth and seamless integration into your existing network.
- NETGEAR AXM765 - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-T
- Data Transfer Rate
- 10 Gbps
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 100 m
- 5-year warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-T
- 10GbE
- 10 Gbps
- 100 m
- IEEE 802.3an, IEEE 802.3bz
- 1 x Ethernet 10GBase-T - RJ-45
- Limited warranty - 5 years
