Netatmo Smart Siren
Quicklinx: H4RXWS00 Mfr#: NIS01-UK
Leave your home with peace of mind. With the Smart Indoor siren, complete your smart indoor camera and get a security system that detects intruders but also scare them away.
The Smart Indoor Siren and the Smart Indoor Camera team up to keep your home extra secure
When an unknown face is detected by the Netatmo Smart Camera during your absence, the Siren immediately triggers a powerful 110 dB alarm to scare away the burglar.
The Netatmo Smart Camera uses face recognition and people detection to only trigger the Smart Siren when an intrusion occurs: no false alarms caused by a family member, a pet or a harmless movement.
Alarm arms and disarms itself automatically
Did you dash out of the house to catch your train and forget to switch on the alarm? No problem! The Netatmo Smart Alarm System arms and disarms itself automatically when you leave and return home.
You can relax: your smart equipment is programmed to help you! In addition, facial recognition prevents the Smart Indoor Siren from going off when your children come home but raises the alarm if it detects an intruder while you are away.
Easy to set up
Smart and straightforward - that’s the thinking behind Netatmo products. Start by downloading the Netatmo Security app and follow the instructions. Simply place your Smart Indoor Siren on a shelf or table or fix it to the wall next to your Indoor Camera.
The Netatmo Smart Indoor Siren can run on battery power or plugged in - it’s up to you
Pre-recorded noises make it sound like there’s someone home
The wireless Smart Siren comes with a variety of pre-recorded sounds such as dog barks and other home noises.
You can choose to play them in order to simulate presence and thus deter burglars from entering your home.
Your Smart Indoor Siren tells you when someone tries to disable it
The Netatmo Smart Indoor Siren alerts you when someone tries to disable it. You receive an instant notification on your smartphone while your Indoor Siren sounds its 110-decibel alarm. Deter intruders and prevent break-ins effortlessly.
Set off the alarm from your smartphone, wherever you are
Your Smart Indoor Siren is ready for anything. Wherever you are, in an emergency you can trigger it remotely via your smartphone. If you suspect a break-in while you’re at the end of the garden or visiting a neighbour, simply sound the 100-decibel Netatmo Smart Indoor Siren to scare the intruder away.
Netatmo Smart Indoor - siren - Bluetooth
Siren
Environment
Indoor
Power Source
Wireless - Bluetooth
Siren Sound Level
110 dB
Supported Host Device OS
iOS, Android, Windows, MacOS
United Kingdom
1-year warranty
13 cm x 3.5 cm x 13 cm
Siren
Environment
Indoor
Power Source
Wireless
Siren Sound Level
110 dB
iOS 10 or later, Android 5.0 (Lollipop) or later
Tamper detection
Internet of Things (IoT)
Communications Technology
Bluetooth Low Energy (LE)
AA type
Battery Included
Required Qty
4
Battery Lifetime
2 years
Mounting kit
United Kingdom
Warranty
1-year warranty
FCC
13 cm
3.5 cm
13 cm
282 g
