Netatmo Smart Outdoor Security Camera With Built-In Siren White
Quicklinx: H4RVWS00 Mfr#: NOC-S-W-UK
  • microSDHC Card
  • microSD Card
Receive real-time alerts and deter intruders in the event of a break-in
An intruder on your property? The Smart Outdoor Camera with Siren immediately sends an alert to your smartphone and scares away the intruder with its 105-dB alarm.
Materials:
A sleek design for a two-in-one camera The Smart Outdoor Camera consists of an upper part containing a floodlight and a lower part containing a camera. Anodised aluminium monobloc This material is designed to last without degrading and to protect the technology in the product. Glass and plastic Highly resistant glass and plastic protected against UV HZO protection Materials with HZO protection to withstand bad weather
Technologies
Night vision Day and night protection with infrared night vision for clear video images, even in total darkness up to 15 metres away. High-definition video The Full HD 1080p Camera offers the best quality video so you can clearly see what’s happening in your home. Choose security Your data is 100% secure with storage on an encrypted microSD card.
  • Be alerted in real-time
    Your Smart Outdoor Camera with Siren knows the difference between a person, vehicle and harmless movement. Just choose which events you'd like to be alerted for.
  • Scare away intruders with the Smart Siren
    The Smart Outdoor Camera with Siren has a 105-decibel alarm that alerts you and deters intruders.
  • Fully secure data
    For security and peace of mind, your videos are processed locally and stored on an encrypted microSD card. When you want to access your footage, the camera sends the video to your smartphone via a secure VPN. If you would rather store your content on the cloud, that's fine too! You can store your videos on your Dropbox account or your personal FTP server.
  • Use the smart lighting system
    Your Smart Outdoor Camera has a built-in lighting system that comes in handy in various situations. If it detects a person, the light will turn on, which can scare off intruders as well as light up your path at night. It can be turned on manually from the app or set to turn on when a person, car or animal is detected.
  • Simple installation
    If you have an existing light, simply set up your Smart Outdoor Camera in its place. You can also choose a different location to monitor your property - it's up to you.
Netatmo Smart Outdoor Camera with Siren - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
5 cm x 11 cm x 20 cm
White
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Optical Sensor Type
4 MP
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Platform
Apple HomeKit
Intelligent Assistant
Alexa, Google Assistant
Voltage
AC 100-240 V
100° field of view, built-in flash light, built-in siren (105 dB), memory card encryption, People Detection, Vehicle Detection, aluminium housing, UV-resistant plastic and glass
Wireless
5 cm
11 cm
20 cm
United Kingdom
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
15 m
Image Sensor
4 MP
Network Interface
Supported Memory Cards
microSD Card, microSDHC Card
Mounting kit
White
Power supply - internal AC 100-240 V
Internet of Things (IoT)
Platform
Apple HomeKit
