Netatmo Smart Carbon Detector
Quicklinx: H4RYWS00 Mfr#: NCO-UK
The Netatmo Smart Carbon Monoxide Alarm measures carbon monoxide levels in the different rooms of your home in real time. This invisible, odorless and poisonous gas can be deadly. Does your home have a fuel-burning appliance like a boiler, fireplace, wood-burning stove or gas cooker? The Netatmo Carbon Monoxide Alarm will carefully monitor the carbon monoxide particles emitted by these appliances, alerting you if you and your family's health is at risk.
The Netatmo Smart Carbon Monoxide Alarm lets you know in real time if it detects a dangerous level of carbon monoxide in your home. If you're at home, the 85-decibel alarm goes off just like a conventional carbon monoxide detector. If you're away, it instantly sends a notification to your smartphone. This means you can take immediate action, wherever you are, by making sure your family evacuates the house and calling the emergency services.
  • Detector that looks out for your safety day and night
  • Carbon monoxide alarm that alerts you wherever you are
  • Decade of serenity thanks to a 10-year battery
    Carbon monoxide detectors last a maximum of 10 years. The Netatmo Smart Carbon Monoxide Alarm is equipped with a unique 10-year battery. It's so practical! You never have to replace the batteries, and when you receive a low-battery alert you know it's time to replace your Carbon Monoxide Alarm.
  • Carbon monoxide alarm that tests itself
    The Netatmo Smart Carbon Monoxide Alarm checks itself to make sure it is working correctly. The Self-Test feature monitors the carbon monoxide sensor, battery, and Wi-Fi connection. Low battery? Connection error? The Carbon Monoxide Alarm immediately sends a notification to your smartphone. Still not sure? Check the Self-Test reports at any time via the app.
  • Fast installation
    Install the Netatmo Smart Carbon Monoxide Alarm in minutes without an electrical connection. Place it in any room with a fuel-burning appliance (boiler, fireplace, wood-burning stove, gas cooker, etc.). All you need are the tools to screw it to the wall. Then download the Home + Security app to connect the Alarm to your Wi-Fi and take advantage of its many features.
  • Check carbon monoxide levels in real time
    By activating Bluetooth on your smartphone when you are in the same room as your Netatmo Smart Carbon Monoxide Alarm, you can monitor how much carbon monoxide is in the air in real time using the app. If there is none, then everything is fine. If, however, a low level is detected (up to 50 ppm), you must have your fuel-burning appliances checked by an expert. Rest assured, if a dangerous level is detected (above 50 ppm), the Carbon Monoxide Alarm will alert you so that you can leave the house immediately.
  • Set an automatic reminder to test the alarm
    Use the Alarm Test feature to check the alarm is working well. Nothing could be simpler! Start the test via your smartphone or by pressing the Netatmo Smart Carbon Monoxide Alarm. Netatmo recommends you test it at least once a year. If you think you might forget, the Netatmo Smart Carbon Monoxide Alarm even has an Alarm Test Reminder feature. Use the app to select how often you want to receive a reminder and get a timely alert via your smartphone.
  • Create links with other connected devices
    The Netatmo Smart Carbon Monoxide Alarm is compatible with HomeKit. So, if you have other connected devices, you can set up communication links around the home. For example, when the Alarm detects carbon monoxide in the boiler room, your boiler can turn off automatically via the Netatmo Smart Thermostat or all the lights in the house can turn on at the same time to alert everyone.
Netatmo Smart Carbon Monoxide Alarm - carbon monoxide sensor - 802.11b/g/n - white
Carbon monoxide sensor
Environment
Indoor
Integrated Components
Alarm
Power Source
Internet of Things (IoT) Platform
Apple HomeKit
Wireless - 802.11b/g/n
Siren Sound Level
85 dB
Frequency Band
2.4 Ghz
White
10 cm x 2.3 cm x 10 cm
Environment
Indoor
Alarm
Power Source
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Siren Sound Level
85 dB
Wall mountable, photoelectric sensor
Platform
Apple HomeKit
Communications Technology
Bluetooth Low Energy (LE)
Battery Included
Required Qty
2
Lithium
Battery Lifetime
10 years
Mounting kit
Product Material
Plastic
White
Encryption Algorithm
WPA, WEP, WPA2-Personal
Warranty
RoHS
10 cm
2.3 cm
10 cm
147 g
-10 °C
15 - 95%
