Netatmo Presence
Outdoor security camera with people, car and animal detection.
An outstanding camera, a minimalist design
ELEGANT ALUMINUM DESIGN
The beautiful aluminum body gives Presence a timeless design and at the same time makes it extremely durable.
STUNNING VIDEO QUALITY AND ZOOM
Videos are recorded in excellent Full HD quality. Pinch-to-zoom into the video to see every detail.
RECORDS ONLY WHAT MATTERS
Presence records only when something happens, there are no hours of empty footage.
ENTIRELY WEATHERPROOF
Designed for outdoor use (HZO protection standard).
ULTRA-LONG DETECTION UP TO 20M / 65FT
Presence is able to detect people, cars or animals up to 20m / 65ft. Customize the detection length as you need it.
SECURE ENCRYPTION
Bank-level and end-to-end encryption is used for the highest level of protection.
Detects the presence of a person, car or animal
Presence detects and reports in real-time if someone loiters around your home, a car enters your driveway or your pet is in the yard.
Prevent break-ins or damage on your property
Ultra-precise alerts let you know instantly about what happens outside your home.
Use live stream to view your property in real-time.
Protection day and night
At night, either watch discreetly with Presence's infra-red night vision or switch the camera's floodlight on.
The smart floodlight can be switched on manually in the app or set to switch on when it detects a person, car or animal - or for all three. It helps you find your way safely at night and deters any unwanted visitors.
Entirely weatherproof
Presence is specifically designed for outdoor use and can withstand the elements: rain, snow, moisture, dust and dirt, thanks to HZO technology – an innovative thin-film coating solution.
Simply installs as an outdoor light
Presence simply replaces any existing outdoor light fixture. In just a few minutes you have a sophisticated security system with a powerful floodlight.
Free video storage
Local video storage on the included microSD card.
DropBox - Choose to store your videos automatically on your personal Dropbox cloud.
Or, choose to backup videos automatically on your personal FTP server.
Be notified when it matters
Each home is unique. With Presence you receive customized notifications that match your needs. The Alert-Zones feature allows you to select specific areas for alerts – you know instantly when someone enters a zone you selected.
Be in control of your home at all times
In the app watch live stream from any device, anytime. Scroll through past footage and download your favorite videos.
See the day in a minute
Watch what happened during the day effortlessly with Presence’s timelapse feature – quick to watch and fun to share.
Make your home smarter with Apple HomeKit
Apple HomeKit allows users to control smart home devices and make them work together, right from their iPhone, iPad or Apple Watch.
Just say: "Siri, switch the floodlight on"
Messenger:
Just type: "Switch the floodlight on"
Google Assistant
Just say: "OK Google, turn on the garden light"
                Detects the presence of a person, car or animalPresence detects and reports in real-time if someone loiters around your home, a car enters your driveway or your pet is in the yard.
                Prevent break-ins or damage on your propertyUltra-precise alerts let you know instantly about what happens outside your home.
                Protection day and nightAt night, either watch discreetly with Presence's infra-red night vision or switch the camera's floodlight on. The smart floodlight lights up your way at night and also deters any unwanted visitors.
                Be notified when it mattersEach home is unique. With Presence you receive customized notifications that match your needs. The smart zone feature allows you to select specific areas for alerts - you know instantly when someone enters a zone you selected.
- Netatmo Presence - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- 5 cm x 11 cm x 20 cm
- 900 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Optical Sensor Type
- 4 MP
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 2-year warranty
- Wireless
- 5 cm
- 11 cm
- 20 cm
- 900 g
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Max Digital Video Resolution
- 1920 x 1080
- Infrared LEDs
- Infrared Distance
- 15 m
Image Sensor
- 4 MP
Lens Construction
- Horizontal Field of View (degree)
- 100
- Network Interface
- Supported Memory Cards
- microSD Card
- Included Accessories
- Mounting kit, 8 GB microSD card
- IP66
- OS Required
- Android 4.3 (Jelly Bean) or later, Apple iOS 8 or later
- Limited warranty - 2 years
